Axial yeti kit build
rcaholic13
yakima
So here's my yeti kit build getting close my theme is black on black gonna call it murder one here's the rundown so far
Tekin rx8 gen 2 esc
Tekin rx8 gen 2 black case
Tekin pro 4 hd 3000kv motor
Black aluminum motor mount
Robinson racing slipper clutch
Axial front locker
Vanquish steering rack
Vanquish sheer pins
Vanquish titanium steering links
Vanquish knuckles
Vanquish castor blocks
Vanquish front shock tower
Vanquish shock relocator
Rpm front a-arms
Vanquish rear trailing arms
Vanquish upper titanium links
Currie antirock sway bar kit
Vanquish currie rock jock center pumpkin axle with scale bolts
Vanquish locker
Axial hd diff gears
Team knk stainless steel screw kit
M.i.p rear drive shaft
Hitec 7950 steering servo
Castle 10 amp b.e.c
Black aluminum 3 link mounts
Black aluminum sway bar mounts
Black aluminum shock brackets
That's where I'm at so far gonna order the new vanquish vvd hd front shafts and black on black vanquish methods with the black vanquish hubs and voodoo u4 tires I'll keep you posted
Sent from my SM-N910V using Tapatalk
After a little drimmel action to notch out a little room for the sensor wire I got the holmes motor in can't wait! Almost there..
Oh happy day. It's Christmas all over again... choices to install either the 2.2 black on black method 105, or black on black 101, ottsix voodoo u4 silver compound tires, vanquish slw hubs, vanquish hexs, Deuce's Wild 2.2 Standard Single Stage Closed Cell Foam, things are looking up! One step closer
