Mutt
Someone asked for some tire photos...
From left to Right
-Narrowed Wheel, shallow lugs and sidewall lugs removed (my personal fav)
-Standard Wheel, shallow lugs and sidewall luges removed (insane sidewall flex)
-Standard Wheel, Every other entire treadbar and sidewall lug removed (Eh, its alright)
-Standard Wheel, mod of previous, every other lug again removed, way too much flex not enough tread.
I have since made aluminum skids from cut up cans glued to the plastic, its been used some
Rear Axle Cover
Rear Axle Cover Removed
First Look Inside
High/Low Range selector, notice the small spring by the pivot? This allows the gears on the selector to be pushed past the gear drum until both axles are engaged, the tension is then released and the gears re-mesh. Brilliant!
Passenger Side "Gen 2" axle shaft, wheel bearing, and drive coupler. This white coupler is a common weak point.
Driver Side axle shaft, it engages the actual driving axle by a teeny tiny pin, you see inside the shaft how it engages.
Drive Motor of course
Drive Coupler on left, HIGH/LOW Planetary, HIGH/LOW slider, Drive motor planetary
HIGH/LOW Gear assembly cover
HIGH/LOW Motor setup
This white collar drive coupler is a weak link, the "Gen 3" or upgraded chassis as people know, have metal collars. As you can see at this point my collar is already slightly deformed, you are better off filling this with JB weld and reassembling it from the get-go.
These four small balls are all that are used to connect the drive planetary to the HIGH/LOW Range planetary assembly, slap some grease on these and grease the gear boxes and things work much smoother and quieter.
A Small pin on the far right side of the metal shaft must be removed, a pair of sidecuts used to wedge and wiggle made short work of its press fit, don't loose this pin as it actually drives the driverside tire.
The inner workings of the HIGH/LOW Planetary, the blue gear is a direct drive portion while the white ball/shaft assembly gets driven further into it in LOW and then drives the small 3 gear planetary.
HIGH Range
Inside the HIGH/LOW Gearbox
LOW Range Gears
The drive motor planetary assembly
LOW Again
Steer axle cover
Steer Axle First Look
Passenger Side Knuckle
These are press fit into the knuckle bearings, the knuckle bearings are pressed in as well.
This pin must be removed from the pitman arm in order to pull the steering box
Steering box pulled from steer axle
Cover removed from steering box
As you can see, LEFT to RIGHT. Steering position sensor, Pitman arm, Spacer, Steering gearbox (3 stage planetary!), Steering motor on bottom.
Sorry, removed the drive motor cover before taking a photo of it or the planetary assembly, almost identical to the rear assembly.
