BENDER Customs SW2 chassis.........
I just ordered a chassis. I can't wait for the next batch to be finished :mrgreen: Thank you Bender.
Andrew
I forgot to ask this. I do not own a TLT. What do you reccomend I use for cross-braces?
Thanks,
Andrew
Thanks,
Andrew
You could make your own, they measure 2.1". If not, try posting in the wanted forum. I'm sure there are tons of them floating around.
canadian whiskey said:
will a stampede tranny still work in your chassis if the screw holes facing the axels are cut off? james.m
The only 2 mounting points for the tranny in the SW2 are the stock Stampede suspension pivot points.
If you've cut them off, you can get a new housing through Tower Hobbies for cheap.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJK65&P=Z
Thanks,
Andrew
Hey C.M. you could P.M. Norwegian Legion.
He could probably help you out. ;-) (Sorry N.L. :-P)
I had a pede in mine that had the ears cut off so It can be done.I took a peice of L channel aluminum and drilled the holes in the aluminum for the chassy to mount then drilled holes in the bottom of the L channel for the tranny to screw to and it worked great.I will see if I can find pics of what I did but it's really simple if you look at it.
Bender,
What size are the two mounting screws for the transmission? I want to replace them with stainless steeel hex hardware.
Thanks
rctruckchopshop said:
Bender,
Thanks
They are 6-32 x 3/4" long, with a couple flat washers.
i forgot to ask, what body mounts are you using?
and any updates as of yet on when the chassis will be done?
no rush I still need to get thicker shock oil and red springs. casue i got my msr4 shocks and put 35wt oil in them with the stock 2 hole pistons and its way to little dampaning, for my tastes and im to lazy right now to try the 1 hole ones lol. and the springs feel like they could hold up a 1:1 scale crawler lol.
i cant find red losi springs that are 2.75'' like the white spings i have all i found were these https://www.ssl-stormerhobbies.com/cgi-bin/seekpart.pl?src=ns&pn=LOS5152
2.5''. are those the ones your using bender?
Yes, those are the red springs I use. I have threaded shock bodies, so I tighten down the rear more then the fronts to make up the difference. I'm using the stock TLT body mounts, they bolt up to the SW2 chassis.
I shipped a the first few chassis' out on Friday morning, the rest will ship by Wednesday.
