BentKa's T1E Mini Moonbuggy
BentKa
_________
Here's a small build thread on my T1E Mini Moonbuggy for the new 1.9" Class in the Norwegian Crawler Series
The spec list:
  • Chassis: T1E Mini Moonbuggy
  • Axels: Losi MRC
  • Links: Lunsford Titanium upper + lower links. T1E High Clearance Delrin in the rear[/URL]
  • Front link/servo plate: T1E
  • Rear link plate: T1E
  • Dampers: Losi Alu.
  • CVD: Losi
  • C-hubs: Losi Alu.
  • Knuckles: Felsenfest 0 ackermann
  • Front axle: Overdrive mod.
  • Lockouts rear axel: Losi Alu.
  • Straight rear axel: Losi
  • Transmission housing: HotRacing Alu.
  • Transmission gears: HotRacing Alu.
  • Driveshafts: MIP
  • Slipper clutch: MIP
  • ESC: Tekin FXR
  • BEC: CC Bec 10A
  • Motor: Crawler Mafia Contraband 17T
  • Servo: Hitec HS-7954SH 29kg./cm. @ 7.4V
  • Servo horn: Racers Edge
  • Servo protector: Vanquish
  • Reciever: Futaba R614FF
  • Batteries: TP 7.4V 325mAh 65/130C
  • Ball bearings: Full Boca Green Seal set
  • Wheels: Vanquish LH
  • Tire: Hot Bodies Rover 1.9" / Losi Mini Rock Claws
  • Foam: Crawler Innovations Nova SS
Stay tuned "thumbsup"
Bent
The basis for this build is a Losi Mini Crawler Pro.
The pro version is equipped with most of the Losi option parts right out of the box:
  • Metal lockers in front + rear axel
  • Metal center locker
  • Losi CVD
  • Losi threaded alu. dampers
  • Reinforced metal driveshafts
  • Carbon fiber chassis
  • Beadlock wheels
  • Losi Mini Rock Claws Blue tires
  • Servo/axel plate for full size servo and space for a battery ++++
Bent
Installed the HotRacing reinforced alu. gears, Boca Green Seal bearings and MIP slipper clutch in the HotRacing alu. transmission housing.
I also got the Holmes Hobbies 33T motor mounted, using MIP motor screws.
Who ever said that a 1.9" Crawler build isn't as much fun as a 2.2" Pro rig :mrgreen:
Bent
Opened up the rear axel to replace the original bearings with Boca Green seals "thumbsup"
I also applied locktite to the screws on the ring/pinion gears:
Installed Losi alu. lockouts and straight axle......
....and assembled the axle casing with longer bolts and nuts on the opposite side to prevent the housing to expand and affect the gear mesh.
I also installed wide alu. hexes:
Bent
That's going to work real nice Bent. "thumbsup" My Moonbuggy 2.2 loves it's GC-2 origin. "thumbsup"
Thanks "thumbsup"
Can't wait to get this mini done and out on the rocks.
Should be a blast to drive as a contrast to it's bigger brother with all the bells and whistles :mrgreen:
No DIG to save your a** when you screw up choosing the wrong line :oops:
Bent
Hello,
good start Bent "thumbsup"
...but one important thing is missimg in your list:
...you can get it here: BWD
Greetings Frank
X2 "thumbsup"
This build thread is beautiful, the photography is just outstanding. Your rig definately deserves this motor plate.
Can't wait to see this through to its conclusion - superb work so far.
Hello,
Greetings Frank
I know, I know.........I didn't find this motorplate until a few days ago actually :oops:
I can promise you that it will be on there though :mrgreen:
And thanks for the kind words Frank.
Looking forward to Supercrawl ;-)
X2 "thumbsup"
Thanks :oops:
Bent
A very Pro build!
I just got the pro roller yesterday and want to go bodiless. With it being so narrow are there any problems moving to what I assume is a wider chassis?
A very Pro build!
Thanks ;-)
They are actually both exactly the same width; 39 mm (1,535")
So far I have had no real issues.
Bent
Hi Bent,
how long you are making the links from eye to eye?
regards
Jörg
Hi Jörg
These actually come pre-cut with the chassis.
Just add rod ends and you're done "thumbsup"
Measurements eye to eye:
Front uppers (w/small Traxxas rod ends): 78 mm
Rear uppers (w/small Traxxas rod ends): 84 mm
Front lowers (w/small Traxxas rod ends + Losi MRC rod ends): 84 mm
Rear high clearance lowers (w/small Traxxas rod ends + Losi MRC rod ends): 84 mm
Bent
Sorry for a bit offtopic Bent :oops:
Jörg, maybe you ask Julian if he could send you the links for it, he should still have them.
Offtopic mode off. If got some 3mm Grade5 Ti laying around, this should be a opportunity for some uppers :mrgreen:
Greetings Frank
Stock plastic lockers? Are you planning on changing these? Build looks great otherwise.
