BIGW0RM
Bigworm’s SCX24 Build(s)
2021 EDIT:
I now have two SCX24's.
Here is a link to the final edition of my OG SCX24 Deadbolt.
http://www.rccrawler.com/forum/micro-scale-rigs/609547-bigworm%92s-scx24-build-4.html#post5980394
And here is where my SCX24 C-10 build is at:
http://www.rccrawler.com/forum/micro-scale-rigs/609547-bigworm%92s-scx24-build-7.html#post6075209
The information below might be old or outdated by now.
Here is my little Yota driven scx24!
MODS LIST:
430mah 2S battery
Hbx devastator wheels.
RC4WD 61mm tall scramblers
Crawler Innovations Soft micro foams.
Emax ES08MAII 2kg servos x2
Four wheel steer via splitter and signal reverser
Two losi micro shocks in rear.
First thing I did was add some rubber o rings around all the steering linkage ball ends. This GREATLY removed a lot of the steering slop. See my picture below for the red circle. Put one or two per ball end and now your linkage wont tilt so much when you turn, thus cleaning up a lot of slop. It REALLY helps a lot.
Shock wise, I simply added some o rings to the top of the front springs to give them some preload (NOT SHOWN). And for the rear I put two losi micro shocks attached to the rear battery tray mount and I get over 60mm of articulation both front or back!!! I am extremely pleased with this. I can climb 49 degrees upward with the body on. I can sidehill up to 41-42 degrees before it tips. I love how well this drives now.
For the 4WS, I purchased a new front axle and two new servos. The servos I listed above FIT. They are not perfect fit, as they protrude out 1-2mm but they FIT and work very well. More than enough torque to move the whole truck of one wheel gets stuck. I also used a y splitter and signal reverse for my 4WS. I plan to use the 3 position switch for a winch or something. I also had to use the other links in the box to attach the front axle so the pinion angle was correct. ALSO, I forgot. When I removed the rear body hinge, I moved the rear shock, mounts FORWARD one notch. I did this because my rear servo was hitting it where it was placed stock. I also added 5/32 tubbing that I bent from one side to the other with some velcro for the rear part of the body to mount too.
Tire wise, I am a sucker for the HBX monster wheels. I just like how they stick out. I went this route over wheel spacers. And now that I have scramblers on the HBX wheels, I am very happy. Plus the HBX wheel has a lot of room for weight. Each one of my wheels is 22 grams. Which might be a tad too much. But it works well!
Power wise I am going to try the RC4WD motor with the 10T once my new electronics land. Or I might throw in a ECX barrage 050 long can motor. While i like the stock electronics a lot. I want to have a crawler mode for 4WS. So a GT5 is on its way and I'll mess with other motors when that lands! Otherwise I would keep the stock electronics. I think they work great!
Sent from your iPhone.
2021 EDIT:
MODS LIST:
430mah 2S battery
