bilinvic
After owning my RTR Wraith for a couple years with what seems like an endless list of mods, I decided to build another Wraith, this time using the kit version since I had quite a few aftermarket parts not being used. This Wraith is for my 7 year old son. He has been using an AX10 Deadbolt and it crawls pretty darned good, but not as good as my Wraith, plus he said it was too slow!
I’m not going to give this Wraith a fastback mod because I like the look of both roof line styles, so one of each will be good!
I ordered up the kit and a bunch of mods from RPP. With my Wraith, it’s always been run it, modify it, run it, modify it....so this time I thought I would do pretty much everything from the beginning. It was a very enjoyable build having all the hop-up parts on hand and bolting them up as the build progressed. When I build another RC, this is the way I want to do it again. I have learned an exceptional amount from my Wraith and the vast knowledge shared on RCCrawler which resulted in this Wraith being built exactly how I would want it….except it’s for my son!
Here’s the specs:
Motor – Tekin Pro4 4000 kV
ESC – Tekin RX8 v2 w/ Hotwire
Servo – HiTec HS-7955TG w/ Axial Aluminum Servo Horn
Castle Creations BEC
Axial Simple LED Controller w/LED lights (4 white and 2 red); I used the two large rectangular light buckets for the “headlights” instead of the round ones to make it different from mine.
Transmission / Driveline:
Axial 5mm 13t 32p Pinion
Axial Wraith transmission converted to use the new Axial dual slipper 56t 32p spur gear;
Robinson Racing One Piece Steel Bottom Diff Gear
Hot Racing Hard Steel Upper and Middle Gears
MIP Axles
Vanquish Wraith Stage 1 Kit; Orange
Vanquish Wraith Shock Link Mounts; Grey (all four)
Vanquish Wraith Axle Truss; Black (front and rear)
Axial Universal Joint Axles (comes in kit version)
Beef Tubes (front axle only)
Axial Heavy Duty Bevel Gear Set; 38t/13t (front)
Axial Heavy Duty Bevel Gear Set; 43t/13t (rear)
Vanquish Wraith Titanium 3/16 Drag Link
Vanquish Products Wraith Ackermann Titanium Tie Rod (I purchased the tie rod intended for the long Ackerman Arms and therefore, it will not work until I order the parts required, luckily I had a spare aluminum tie rod that will work for now)
AMF Racing Aluminum Axial Wraith Differential Protectors
Modified Stock Lockers; The inner metal “locker” was JB Welded into the outer plastic carrier and blue Loctite was used to secure the axles. In the rare circumstance that this will fail, they will be replaced with Locked-Up FI Spools.
Gear Head 2.2 Five Star EZ-Loc Aluminum Beadlock Wheels
Pit Bull 2.2 Rock Beast II Komp Kompound Tires
Pit Bull Foams, Dos Piezas 2.2 Kompilation Dual Duro
Axial Aluminum Lower Suspension Links (comes in kit version)
Axial Aluminum Upper Suspension Links
Using stock shocks for now, but I do have a full set of GMade 103mm XD Piggybacks that I may end up using.
Misc.:
Body – Purchased a new Poison Spyder body from a fellow RCCrawler Member
Traxxas Battery Hold-down Kit x 2; for the hood posts and clips. (part # 3727)
Fabricated a rear floor from Lexan to mount the ESC
Painted the rear floor and interior with Tamiya PS-41 Bright Silver followed up with Tamiya PS-1 for the backer
RC Screwz Stainless Steel Hardware Kit
Front Battery Mount / Rear ESC Conversion; Battery tray fabricated from ABS sheet
That’s it for now….just waiting for the body to arrive to finish ‘er up.
I’m looking forward to trying out the Tekin RX8 v2 ESC, this is the first one I have owned. I’m using a Tekin ROC 412 3100 kV motor and MMP in my own Wraith. So far, I have found that the Castle Creations software is much more user friendly than the Tekin Hotwire software. I will use 13t pinion as a baseline and go up or down in teeth as required.
On to the pics…..
Here’s the specs:
MIP Axles
Misc.:
On to the pics…..
