Brazin Scale RC HiLow 10.2
BrazinScaleRC
mishawaka
Scx10II compatible Brazin Scale RC chassis are here!
Please read entire post.
We are proud to release our newest design, scx10 or scx10II compatible lcg chassis.
This will be the most versatile chassis on the market for beginners or veterans alike.
Chassis features include:
1) Integrated shock hoops for added shock placement and adjustability for a wide range of suspension setups
2) Lowered belly height for improved center of gravity.
3) Multiple suspension link mounting locations for dialing in suspension geometry for your setup.
4) Bolt in mounting locations for the ever popular toyzuki forward motor mount.
This chassis also makes it much easier for people who want to run chassis mounted servo.
We are also offering panhard mounts designed by JCAD and printed by shapeways in nylon to be used with this chassis or you can simply cut the mount off of your factory shock mount.
*******special notes*******
1) When using JCAD panhard mount, a custom length panhard bar will be required.
2) when using the scx10II KIT transmission, rear most transmission mounts may come in contact with rear upper links in some ride height situations and may need modifications made to transmission mounts or running custom bent rear upper links.
Pricing on these chassis will be $80 including JCAD panhard bar mount or $75 without panhard mount. chassis material options being steel or G10 at this time.
Price is for chassis rails and optional panhard mount only. Skid plate not included.
JCAD panhard mounts are Black when supplied through us at this time, if you would like a custom color, please visit
https://www.shapeways.com/product/4JE8DT6JB/panhard-chassis-mount-flat?optionId=61843776
Brazin scale rc has the best customer service that I've ever delt with. This guy stands by his product and makes some of the best products around.
