you shouldnt give all your secrets away dude. bad fo' buisness.
the plate you braze on, is it aluminum?
could you lay pieces of brakeline or whatever flat on an aluminum plate and braze them w/o the crap stickin' to the aluminum sheet?
What torch are you using?
dumb question but, does that torch not use oxygen too?
great vid.. could you post a picture of the pieces. like you mentioned before it's not clear in the video but i still picture might help.
Double J,
On a normal build would you have to braze the other side of the joint
or did it flow all the way around??
That was fast for what i expected..
Very, very informative!! Thanks"thumbsup"
warning very noob question!
is silv just regular solder? or somthing else. hope to build a full droop tuber somtime in the near future!
