Redfinger
I had to do a repair once on my VW(real car) and it invloved welding some thin stuff. I too have a Lincoln 110 gas set up. try this, get uyour self two wash cloths and a bucket of water, dip the cloths into water, then wrap the cloths around the pipe on either ends of your weld, dont let the area your joining get wet, keep it about a 1/2 in or so away. Then quickly tac away. The wet cloths may act as a heat sink and absorb the heat before the metal does, one other suggestion, get some broonze or brass or copper tubing w/ a ID of the same OD as the brake line, or you could get some SOLID brass stock that si the same OD as the ID of the tubing.....you follow?
Great
Now take the solid brass stock and put it inside the tubing, but your two ends to gether and tac. The brass will not weld, and it will pull the ehat from the tubing.
Goood luck
Ashton
Great
Goood luck
Ashton
