Almighty Malach
More than super 300 steering...... I have XR-10 universals with longer beef tubes on my sporty and its awesome.
Copycat!
I think that's reason enough to give it a try. 1/2" is pretty good. "thumbsup"As it is now, this mod adds almost a half inch to the width, so it may be enough.
I've wanted to do this mod ever since I saw it in EGRESSor's Sportsman thread
Mine differs just a but from his. I didn't cut and weld the shafts, and I'm not using toobs. I'm also just using the stock plastic pieces I had leftover from my XR-10. This mod was originally intended for my SCX and those parts should be plenty strong for it. This truck will more than likely get VP upgrades. But for now...
The first thing to do is cut back the shafts 11mm.
It's very important that the two flats are parallel so I made a quick V-block and put them into the mill.
Here they are next to the stock AX-10
As you can see, the shafts are pretty small compared to the stock piece. I don't think I would trust doing it this way if I was using the stock lockers, but I have developed this habit lately where every time I open an axle, one of these XHD No Slop lockers finds it's way inside. I love these things and honestly believe they have made a noticeable difference in how this truck, and my scaler climbs. They are definitely going into my 2.2 Wraith Axled truck soon.
The bearings were pretty shot, so I decided to replace them all with one of Boca's AX-10 Axle kits. I kept seeing Boca advertising on RCC so I thought I'd give them a try. Very fast shipping and great customer service.
Once the locker was mounted and bolted down, it was time to grease it up. I've been using Norm's new grease and really like it. Much better than the Bel-Ray synthetic I had been using.
The stock XR-10 C's require you to put them on before you insert the shafts. Since the locker needs to be installed with the shafts first, this is no longer possible, so the ID of the C needs to be opened a bit at the end. I used an X-acto to get most out, then a .5" drill bit by hand to clean it up. This does not affect the splines.
The C's fit MUCH tighter than the stock AX-10 parts. I had to trim off the bosses where the screws went in. Then I drilled the C's and tapped them for M3 for a bit more strength. M3x6mm button heads finished it up.
...now to find that precious commodity...time.
Lookin' good. "thumbsup"
How is life without dig?
I wish Axial would make universals for the AX10. I'd buy them in a heartbeat.
That is looking sweet"thumbsup". What is causing the steering to stop? Is it the servo or shocks/links? This is just my thoughts but you could add a bit more caster and get the tires swinging a little different. It looks like you could gain a few extra deg if the tire swung above the servo and below the shock. I will reserve comment on that draglink lift kit:ror:
looks good....wishing I didn't live so far away from the space.....
