C.s.r. Bj v4
Gerry
Austria
Every project has an beginning:
file.php
:twisted:
Following parts I´ve installed:
XR10 Axles
y-town´s BJ V4
VP Knuckles
VP Lockouts
HR Gearbox
HR motor plates
DNA Rims
and some other Parts made by myself...
Let´s take a look:
file.php
file.php
file.php
with best regards from Austria
Gerry
I wanted to use this day to practice for the next Comp...
But last night it´s snowing :x .... Well, so I had to do something else at the time going around :lmao:
I´m even looking for all-round rims and so I made my own wheels... I wanted rims that are right flexible - flexible in terms of width and the offset ...
The wheels are in several sections and consist of following parts:
front and rear ring (Beadlockrings)
2x U-ring - these are the outer rings of the rim , where the tire is threaded middle rings - one ring is 5mm ...
file.php
file.php
file.php
file.php
file.php
the narrowest rim which I can now assemble measures 10mm and in 5mm increments and then goes upwards "thumbsup"
Now i have to take some Vanquish Hex Adapters and then let´s practice!
Greets from Austria,
Gerry
There was a slight change of plan, i have made the Hex Adapter myself... "thumbsup"
Then i put the rims at the rig- fits great!
And now it´s time to practice a little bit :mrgreen:
file.php
file.php
file.php
Best regards from austria,
Gerry
nice rig. just to let you know, you will want to ditch the stock upper links. they are way to flexable. i used the 30 degree tube links from axial. much better, no flexing. keep up the great work. "thumbsup""thumbsup""thumbsup""thumbsup"
Thank you guys! "thumbsup"
Yeah, i will made next time the upper Links with 8mm Delrin "thumbsup"
It´s a little time ago since i´ve posted the last time :oops: But a few little things i´ve changed on my XR10 :mrgreen:
Chaotic Crawlers Titanium Lower Links
RC4WD Gears
Vanquish motor plates and gear housings
selfmade accu "plattform"
Eric D_Lux Knuckle Weights
and last but not least - some awesome skins from KrawlerKonzepts for the BeetleJuice V4 "thumbsup"
On friday i drive to Lichtenstein / Balzers to the first SMC Outdoor Comp this year - lets rock the Stones!
Gerry
Im guessing the battery plates he has made. One on the top of the axle a la Rowdy, and one behind the gearbox.
Still looks great. What is the accu platform?
:lmao::lmao::lmao:Yeah, battery plate is the right word for this what i mean :lmao:
But the one mounted on the top of the axle is actually not mounted on my xr10, i love the version behind the gearbox/motor "thumbsup"
Gerry
