Castle Creations esc Problems...
symplyrrc
usa
Hello, I have the cc sidewinder esc on my ax10 and it works great until my range gets over maybe 10 ft then it glitches like crazy.. does anyone else seem to have the same problem?
I had the same problem with my 2wd buggy after i had done some organizing of my wiring. If you have some wires that are tiewrapped together, undo em and stretch those wires out. Mine was because of a wrapped wire that was from my transponder that was right next to my receiver.
gluck
how close are your power wires to the receiver? I am pretty sure you will pick up interference on any wires running parallel to the power wires. Some times they twist the wires to help eliminate this. This maybe one cause of the glitches. Pics of your set up would help.
usually glitching is a result of interferance with the radio system. what radio are you using?
am? fm? 2.4?
