CEN RC Monster Truck Series...thoughts?
HRP can distribute these. So if any lhs you go to uses hrp, they can get it.
Sent from my LGMP260 using Tapatalk
PHP:
Anyone seeing these showing up anywhere? Thoughts and pics if you already have one
Sent from my SM-G955U using Tapatalk
I’d snap some if I was home, but first impressions are good, seems like a well put together rig for the money, tires as expected are pretty bad but other than that it’s good for a rtr.
I got one. I went for the HL150.
First impressions:
Way too stiff sprung and dampened. Took out 1 spring on every corner. Quite the improvement. Now for some thinner oil.
For the rest of it, it makes a rather solid impression. Comes with swaybars that You’ll have to assemble yourself.
Tires are not too bad, but, as expected, more geared towards low wear, than grip. Kind of a good thing, because with the stock, super hard, spring and damper setting it lòves to take corners on 2 wheels, so hard tires make it possible to ‘slide’ for a bit before going full turtle-up..
Size is a tad bigger than a long wheelbase Wheely King. Somewhat heavier, though. Metal gears and a fat 550 ‘ll do that. Pretty fast with the included 15t ( ? ) 550 even without swapping the gears around to increase speed. Steering is a bit wobbly with all the linkages going-on. ( like the WK)
The best thing? No rattling ‘clutch’ like the WK, but a proper slipper.
All in all a pretty solid offering I’d say. Apart from fiddling around with the shocks, there’s not much needed to get it up and running satisfactory.
Sounds great...
Especially the bit about getting some slidin' on.
Post some pics!
Sounds like a solid rig....now I'd like to see them hit shelves. Parts support is what I'm afraid of. The release doesn't seem to be widespread as I was led to believe
Sent from my SM-G965U using Tapatalk
It’s distributed via Robitronic overhere in the EU.
They usually keep a good stock of parts for the cars and accessories they sell. No idea how it will go for the US, though.
I made it to the LHS today and saw one. Its smaller over all then I had hoped for and I think I'll just build up my SCX10ii into an MT until the new SMT10 comes out.
It's the same size as a scx10ii with smaller style axles. Problem with making a scx10ii into a MT is you will only have locked diffs.
