Gimpdiggity
Hello everyone.
I'm going to ask this question despite the fact that I am 100% sure it's been asked before, but I haven't been able to find what I would consider a great answer, despite reading a TON about this truck.
I have an Axial Honcho. I have two Tamiya CC-01s.
My Honcho was my go-to trail truck, until my wife discovered that she actually enjoys driving on the trails, and she kind of "took" it from me as her own when we're going trailing together.
That means that I've been driving one of my CC-01s. The other one I don't drive much, because as much as I hate to say this, I don't want to get the body all dinged up because I was so proud of my paint and body work on it...but anyways, the CC-01 that I've been driving has suddenly started having some issues with it's steering. I kind of knew it was going to happen eventually, but the last couple of times I've got it out, it has not wanted to turn right pretty much at all. The servo will go from side to side perfectly with no load on it, but as soon as I set it down it won't go to the right at all. The fix for this is a PITA...basically, I have to pull the entire front end apart and put it back together. I'm not sure what is getting stuck, as everything SEEMS to work just fine. When I get it back together, it works again for a few days then locks up. Anyways, I'm sick of it, so I'm thinking about retiring it.
Anyways, after all of that, I get on to my question.
I like the Crawler King because it fits my budget really well, I've had good luck with my other two HPI trucks, and I'm kind of drawn to oddball RC stuff.
The thing is, I can't seem to find what I would need to do to it in order to make it a good slow moving trail truck. I know about the torque twist issue, and I've read that a bit of preload on the right rear shock can generally "fix" that...but is that a good solution for just trail running?? There's no serious climbing or crawling, just kind of hiking while driving the trucks on a hard packed mountain bike trail.
See, I seem to find that people say it's a perfect truck for trail running, or they say to stay away from it like the plague because it's so terrible.
I've seen videos of the torque twist, and it seems to occur only when giving the truck quite a bit of throttle, which I don't think would happen very often where I'm going to be running.
My main concern is the "fix" of using the preload...will that in any way have a negative impact on using the truck on trails?? I could see it being a bit of an issue for a crawler that you want more and equal flex on all the wheels, but for trail running I can't really imagine it's a real problem.
Thanks in advance for your help and patience with this question. I've done a lot of looking, and it seems about 50/50 that the truck is what I'm looking for/is not what I want.
Thanks.
Jeff
Thanks.
Jeff
