inebriatedmarmoset
just a thought, some people dont realize. i like your rig though. i have been considering either the team integy crawler coversion with strc chassis, do i have to mount steering servo to the axel with these parts, i basically have a stock wk.
right on, man. yeah once i started using that motor cleaner I've never gone back...it's made the hobby so much more enjoyable behind the scenes and has cut my maintenance time to 1/10 of the time but still gets the same results and prolongs the performance of my rigs.
But yeah, if i'm not mistaken, the stock wheely king has the servo up in the chassis as did the stock crawler king. i still have a lot to learn as i've only been in the hobby for several months but have grown on the CK as a project, not too big of community of WK/CK crawlers out there, but for the most part i've found on this forum and others that the servo mount over axle mod would be the first and best mod to start out with if you want get on the path to some serious crawling. i mean out of the box, the ck was cool, fun to play with, but not really a contender as far as crawling goes. and as soon as i mounted it over the axle with the kit i got from ckrccrawlers (including links too, the ones in the pic above at OCRCraceway), i immediately noticed a difference in performance, you get soooo much more steering and control which was the main complaint for the ck hands down. i did up the servo which i would also recommend doing at the same time to be able to have it bite when you need to while turning, i sprung for it and got a hi-tech digital 7955tg which has given me more than enough torque but im sure you can still get the performance you're looking for with something not as big of a powerhouse. I also did have to play around with it to get the right "fit" adjusting the steering links constantly and checking the max end points so that i wasn't stressing the servo, causing potential damage to the gears inside and would also produce alot of heat. and with that digital servo, im also planning on upgrading my TX to get the end points precisely set and safely get the most out of the servo. it took a while actually, since i sort of had to dick around with it curiously but carefully, but it was still fun nonetheless.
the servo mount kit i got was here
http://www.ckrccrawlers.com/ckrc-aluminum-wk-steering-kit-p-2279.html
but it mounts it at like a 45ish degree angle and i worry that the small clearance between that and the battery bay may cause whatever probs for the servo on like drops where i it would easily get in contact with the battery bay
I've been looking to try out either of these mounts here
http://www.rcguy.com/product-p/me-009.htm
or
http://www.punkrc.com/index.php?mai...oducts_id=29&zenid=1c0hi6fuu3p4to7tddkkllf9l5
to see which may provide better clearance, as soon as i do, ill post it here, although with the one from rcguy it requires you to rotate the shock mount 90 degrees to the rear of the axle and doesn't come with any extra steering links, which came in as a handy replacement when my strc ones broke off, ;-)
Either that, or what i've also found here on rccrawler is that alot of peeps just make their own, which would be awesome, and there are threads with templates to work from if you have the tools/time/resources, (i've been looking at this one here http://www.rccrawler.com/forum/showthread.php?t=64145) i would love to do that and would take pride in the fact that its something you produced from your own hands, which is half the fun in my opinion, but i think thats a bit later down the line for me, though its another route you can take if you can do it :ror:
and the integy crawler conversion kit looks pretty sweet, haven't found alot of feedback about it on rccrawler, although i do notice alot of integy bashing just generally here and there heh, but that kit looks like it would still bump up the performance, i've certainly been looking to get some bent links, might be considering that kit myself! the chassis is also next on my list, and was also looking at strc's for starters, not sure what else is out there yet haven't really done the research yet, if anyone else can offer suggestions???
again, i know i've got a several months but def still feel like a noob so that's just my 2 cents from my exp! sorry for the rant heh
and thanks for the support! it's been awesome building this rig
