lostissues
what do you use to cut your brake line? i want to be able to cut it at a 45 degree angle. I have a jig saw but the blade is flimzy and will not cut very well. I have a bandsaw that is currently out of commishion but I believe I will run into the same problem. I also have a craftsman 10 inch chop saw and I have been trying to locate a blade that will cut metal unfortunatly I hvae been unable to find one. I have checked my local sears and home depot and when I get a chance I will check my local tractor supply and lowes. I could use my dremel but that would make for sloppy cuts. I have been using a pipe cutter but that only works for straight cuts. I may have to resort to using a hack saw and a jig.
anyone have any other suggestions?
Thanks,
Jonathan
Thanks,
Jonathan
