DLUX Knuckles for EVERYTHING !
I always thought it is better to push the weight out to the farthest possible location on your axle?
Plus having the weight inside the wheel hide it from the rock?
I'm glad the cat is finally out of the bag.... Maybe now I can finish a build thread:mrgreen:
Yeah, Wright! :mrgreen:
Im stuck in that berg inner berg outer 300 spot. If i would of known i would have had you throw these on and not got the other weights. lol How long till we can order a set?
Yeah, I get so many PM's from people in your situation! AX10TN was in the same boat too with his 8* Axial/Axial axles. He had no where to run without spending a ton of cash and all he really wanted was a better steering arm setup, not to mention the Axial 8* knuckle weights are lacking. Now he can keep his axles and kill the other flock of birds with one stone.
Trust me, when I wrote that email to you I had a hard time not getting you into another setup. Problem is that I need to refine some of the testers knuckles first and if I start selling these it will just be a big mess.
I am about 2 weeks out from starting any. I should be able to take orders within a week? I would be happy to take the weights back if you want to hold off.
Which is heavier, WC loaded Delrin or solid brass?
Brass will differ depending on the bearings used but should land somewhere around 4.6oz. I think the delrin will be about 3oz loaded with 4 tungsten slugs?
Thats what these knuckles are all about. Figure out what you want and make it happen. You will get lots of preferences from a lot of people. I am not sure there is one perfect answer at this time.
Vendors thread for knuckles:
http://www.rccrawler.com/forum/axles-trannys-t-case/472444-dlux-custom-knuckles.html#post4575557
