JeremyH
Oh, the only thing that is not spelled out in this mod is the screw length
IIRC, I used a 10mm button head and I needed a washer under it to get the proper length and not hit the CVD pin retainer.
Oh, forgot to mention. When taking everything apart I fond a bent CVD pin? Normal, defect or was I being too hard on this car already?
Yeah, is there another option?
Maybee its the way I drive or the rock we comp on but I had to replace my gunner pins after every comp because they were completely bent. So bent that they required alot of effort to remove. If left in two comps they would fail completely while on course. I had the same issue with the rc4wd pins.
I switched to a differant pin and after a few comps now they are still straight and true. Just saying.
What pin did you switch too?
Looks like that part# is 91595A070 which is a pack of 50 - 2.5mm X 14mm
And it say's they have 1,100 lbs. shear strength.
Neither unfortunately.So....you doing a complete redesign or just beating the piss out of this thing?
