Does this fit the scx6 Jeep and Honcho ?
I dont know but I would think it should fit. To check I like to compare part numbers of each model (from the manual) to see if anything changed between them.
I will just add that personally I think the flex in the stock 2 speed servo mount is pretty benificial as it allows the servo to move a bit when the dogs dont immediately mesh.
In looking at it and comparing it other pictures, I came to that same conclusion, and so I purchased it ;-)
It could, but it also might operate/function better if the tolerance's remain consistent.
Guess I know when I know !? But generally it's cheap to buy (I in a realm of nearing $ 200. for nearly everything purchased on this behemoth).
So it's not a big investment or loss if it turns out to be less then worthwhile ;-)
Both Honcho and Jeep have the same internals in transmission and servo mounts. You should be good to go! Sorry, I just noticed this was asked in Sept of '23.
