4ONDFLR
on my sons artr the drive shafts keep coming off the output shaft of the trans. its like the set screws arent strong enough to hold it on. is there something i can do to keep this from happening or would new driveshafts help?
if i run those then i still have the problem i have now. its not the shaft coming apart. its where it slide on to the output shaft of the tranny. it keeps sliding off there. nothing breaks i just have to slide it back on. it just gets annoying after the 10th or so time
If it has the metal yoke, then use locktite on the set screw. If it has a plastic yoke, change it out to a metal one ( and locktite the set screw)on my sons artr the drive shafts keep coming off the output shaft of the trans. its like the set screws arent strong enough to hold it on. is there something i can do to keep this from happening or would new driveshafts help?
X2 "thumbsup" On the axle side also.I run 2 set screw's on each yolk. I put a small dimple on the non flat spot side with a drill bit. Put a small drop of loc-tite on each set screw. Check them often.
buy some of these and never look back. They are cheap, they are a perfect fit and I've been running the same set on my comp rig since I put them on back in June :shock:
not one shaft failure yet.
http://www.tcscrawlers.com/Traxxas-Stampede-Half-Shaft-Set-2-each-1951-p-16157.html
and try searching next time, this question gets asked a lot on here.
