Vitamin_J
This little crawler really surprised me with how good it is. I am having tons of fun with it. Stock it's good but not great so I have done a few mods and will do a few more. End goal will be to have something I can use in 1/24 crawl comps.
I also have an SCX24 and obviously there needs to be comparisons made but I will do that later in the thread I want to talk about the Sendero!
I crawled with it quite a bit stock and really liked it a lot. The only bad behaviors I noticed was the front end lifting on steep climbs and the side-hill ability wasn't as good as I expected. It only has 1S power so it doesn't have the wheel speed of some of the other crawlers, but surprisingly it has really good torque and smooth torque delivery. The stock steering servo is also really strong, I have no need to upgrade it even with stickier tires. The suspension is really, really good. It has soft springs with friction dampers so it doesn't bounce around, it flexes like the real thing.
I made this little review video when it was completely out of the box stock:
https://youtu.be/JtbwlWR3kjQ
This truck is very light and I can tell the design philosophy behind this truck was to keep it simple and as light as possible so I will be building on those strengths as I modify it.
The first thing I did was make a new 3D printed battery and electronics tray. The stock tray sits needlessly high above the chassis and puts the battery towards the extreme rear of the vehicle. I moved the battery forward and lowered it against the chassis rails and then moved the ESC/RX to the rear. Note, I oriented the ESC/RX with the wires towards the front because that was the heavy side.
Stock tray 5g:
New tray 4g "thumbsup"
Installed:
I realized after I installed it that I could have lowered it a few more mm and still had full clearance to the axle so I will do that next
The tray is on Thingiverse for anyone to download and 3D print your own. I'm guessing it will also fit the RGT: https://www.thingiverse.com/thing:4739192
Stock tray 5g:
Installed:
