ESC - can I have it all!
Cheers Hal, encouraging to read you dont have heat issues when using that method with the trim.
So maybe you are going about this in the wrong way. I have a Mamba x in my Bomber and pro 3800. I love it. The way mine is set up I use the throttle trim set up on the lever on my Mt4 pro to dial in the brake. The Mt4 has a lever I use for my MOA to dial in frong to rear bias dig. I have the same lever set as a second throttle trim on my Bomber. I also have the 2 speed and use as needed. This rig is a great all around trail rig. It is very fast and is a very capable crawler. I just use the lever like a switch. I have the end point set to just trim enough to turn off the drag brake. I have never noticed it getting warm at all using it this way and I run 3s all the time. So if you can set up a switch, button or lever on your radio it is a quick flick of a button and the brake is off. The only problem I do have with my bomber is blowing the tires off the beadlocks at high speed. I also have never noticed any noise from it except the fan. My Hitec 7990 servo is a noise maker though. It makes a lot of noise trying to center itself."thumbsup"
Sent from my Pixel using Tapatalk
