ESC mounting
smokediver
Hayesville
Ok I found where people mount there ESC to the front links but I can't figure out how you mounted it I have a CC sidewinder that I am trying to mount and I am stumped..:|
there should have been a triangularish lexan plate with 4 slots drilled in it that came with your kit. i just loosely zip-tied mine to the top of the links
Take a scrap peice of lexan, thin aluminum, scrap cd case, whatever, then make a plate and zip tie it to the upper links, put some double sided tape on it and you should be good! "thumbsup"
Try the side of the chassis
I know a lot of guys are mounting them on the upper links but I did not want to risk the chance that the lexan would impact suspension so I mounted mine on the inside of the chassis sideways basically and it has worked great. The reciever is on the other side. All of this is at the front. end just under the cross piece.
