Everest 10 Driveshaft
Truckmechanic304
Charleston
I have 2 Everest 10's and on both trucks I have a horrible time trying to keep the driveshafts on. After only a few minutes running they will through them off. I have tried thread locking the set screw and that didn't help.
Any other mods to help with this?
I had the same problems. I had upgraded the stock motor to a 37 turn motor, whic is a lot more powerful and this may have led to some of my....er...pains. :cry:
I ended up curing it, but it took some time, money & work. Here is what I did:
1) I replaced the driveshafts with the ones below. You will notice they have a pin that goes all the way through the driveshaft, pin, and provides a secure connection. This, however, led to a problem... my pinion gears and output shafts on the transmission were not drilled.
Xtra Speed Steel Center Universal Driveshaft Axial SCX10 EP 1 10 RC Car Crawler | eBay
2) I bought a set of cobalt drill bits, and - using a drill press - drilled holes in each of the pinion gears to allow the pins from the driveshaft tgo through. Yes, I had to take the differentials apart, pull the pinion gear, drill it, and reassemble the differentials.
3) About this time my transmission died. Instead of replacing it with the same plastic-geared one, I upgraded to this, all metal geared one. The output shafts on it came pre-drilled, so that was fortunate.
https://smile.amazon.com/gp/product/B01A1GT7ME/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
I did use locktite when I reassembled the driveshafts, and they have not come loose in a lot of bashing (even by my 6-yr-old who loves to alternate between full reverse and full foward). :roll:
A long, frustrating road, but it will completely "cure" the problem, as well as beefing up your Everest a LOT!
Hope this helps.
Terry
Thanks for the help Terry.
Do you know if it's possible to change the pinion out to the SCX10 gear sets maybe?
Sorry, I do not.
I ***think*** the shafts are different sizes, so you would need to change bearings as well.
As I have not had problems with the pinions, I have kept the originals, and just modified them.
I don't have a drill press, I was just thinking of other possible solutions.
I could always try to hold it with a vise.
It's possible you got some crummy grub screws, the ends may not be ground square. I'm not sure what size they are, but you can probably get them on ebay. Look for knurled cup ends, they bite into the metal. Avoid rounded and angled tips.
It's a been a slow process, but I drilled all the shafts and drive lines. Waiting on the pins now. I'll post pictures later.
Glad it worked for you!
Te
Terry,
Have you ever been crawling with the guys in Woodbridge? They are a great bunch of guys, usually go out on Sunday in the fall. I'd like to see your Everest if you ever get a chance to make it out sometime.
P.S- sorry for the thread hijack, but it appeared to be resolved. "thumbsup"
