My Axial with Panther Cougars (soft foamed and weighted fronts) has 1 3/8" clearance at the diff (lowest) and 1 7/8" (highest) under the axle tubes. The rear is marginally higher with stiffer foams.
with the arms level, and using my current tires, i am getting a fraction of an inch more ground clearance than you, and thats evenly across from tire to tire ... but then again it is because the mini lst is a scale down from typical crawlers, and so its drivetrain is undersized for my vehicle... lets hope those steel gears will really hold up to all this, if they dont then i will have to replace as much of the aluminum as possible with some sort of plastic or something
Unless I'm missing something it looks like all it does is vary the shock angle though it it's articulation from a softer shallow angle at full droop, to a firmer upright position at full compression.
dont just look at the shocks, but also see the fact that the gearboxes are moving relative to the body, while the wheels are moving relative to the gearbox... when the vehicle is pushed straight down or pulled straight up, it wouldnt matter except for changing the wheelbase, but when there is articulation, what would happen is that one arm will go up, which causes the suspension to pull that side of the gearbox towards the chassis, which would change the angle of that gearbox , which would change the upwards movement of the arm to a diagonal movement, and so on and so on... for the trained eye you will see that the links opposite the shocks are not going to change their altitude too much through the full stroke of the shocks, and thats true... so im planning to buy shorter links to replace those, so as they get pulled inwards by the cantilevers, they will be forced to swing upwards much more...
well, i think its a great idea to combine the indy susp with a...a... it doesnt feel right to call it a solid axle center...how about a floating center? and at the same time, using a single set of shocks to provide suspension for both. I guess i've seen something similar with a maxx suspension but it used a set of shocks for the floating center and another set for the indy.
personally, i call it double articulation
some issues i am having are stuff like there seems to be some resistance to the articulation, maybe if i put ball bearings to support the cantilevers the action will be much smoother ... also the links are rubbing against the rod which they are on, and the lower links are slapping against the surface onto which they are mounted, i hope that shims will solve this... there is some massive binding of the arms with one of the gearboxes which i am not happy about, if i cant find and get rid of it i'll buy a new one, theyre cheap anyways... there are also some badly drilled holes which i will need to fill in with metal epoxy
but the plusses are how the links and shocks have cleared everything around them so well, how i managed to guess the positions of the link mounting points on the chassis, and what im most glad for of all is how it somehow all fit together! this was all done using a dremel and a file... not to mention the drillpress conversion for the dremel, and a bunch of bench vices... ive bought the dremel just for this, and right after the last piece was cut out its speed controller gave in, so it only either went at full speed or its off, no good for plastics anymore
::edit::
this is an articulation shot of what it can do for now
look at the angles of the tyres, and also at the angle of the aluminum bars above the gearboxes... the bar closest to the camera is tilted with respect to the other bar, and the chassis is somewhere in between, its not supposed to be parallel with one of the bars, it looks that way because of the angle... when i fix the problems there will be alot more articulation and the effect will be clearer
