Fat Tire and Cruiser Bikes
Lotta good advice in this thread. And as already stated.. One of THE most important considerations for health, comfort, and longevity of this new endeavor is how the bike fits you... Not only height of frame but also the height of the tires, seat, and handlebars in relation to your body type. Length of the frame is also equally important because although seat and handlebars are adjustable, doing so will also change the overall geometry of your body placement. Angles are also very much at play here. You want to be able to have full comfortable extension and rotation of your feet, knees, legs, hands arms, back, shoulders, etc, etc. to maximize efficiency and dexterity, thus minimizing potential for fatigue and injury.
BTW regarding your inquiry... Yes you can modify wheels, spokes, hubs, tires at any point but don't get caught up in those things right now. Custom wheels or heavier gauge spokes are always an option if you find that you're tweaking your rims out of true but I suggest that you cross that bridge if you ever come to it. A properly built and trued wheel-set will accommodate a good deal of weight. And this is where buying from a reputable dealer ( that also has a reputable tech/ mechanic on site) can really be beneficial.
Also be sure to understand that the right bike for you does not necessarily mean the absolute most comfortable ride in terms of "plush". You're not looking for a sofa to flop down into at the end of the day. You instead need to be in the mindset similar to the level of comfort like a power-tool or work boots.
One of the biggest issues that I faced when I would fit people to bicycles was to get them into the mindset that when one leg was at the bottom of the crank/ sprocket rotation that they needed to feel that full extension of that appendage. People that haven't ridden much or at all seem to feel more comfortable when testing out bikes, to keep a slight bend in the knee and ankle when at the bottom of the crank rotation and that's a huge no-no. You need to be fully extending for the benefit of your muscles and joints. The same consideration should be given ( although not quite as critical) to your upper-body regarding your butt, back, shoulder, and arm extension from the seat to the handlebars.
These factors when occurring properly, will greatly increase your enjoyment as well as your control, dexterity, and muscular and respiratory efficiency long-term.
Something that depending on where you ride, weather conditions, etc... you may also want to consider is hydration. This may not be a huge factor is riding short distances in urban settings but beyond that it's not a bad idea to consider a CamelBak type option OR a frame-mounted cage type of bottle holder. If you opt for frame-mounted then the bike doesn't necessarily need to have the bottle cage installed at the time you buy the bike, but you need to look and see if the frame has the bolsters to at some point install a cage. These will typically be on the down tube or seat tube portion of the frame. And in some instances a bicycle will actually have two sets for two bottles. Just something to keep in mind if you think you might want hydration on board.
Lastly... Don't get caught up too much in accessorizing or buying upgrades until you've had a chance to really get some miles under your belt. One of the things that a lot of people want to immediately change out when they purchase a new bike is getting a new seat. And while factory seats can indeed be a corner-cutting item, I suggest in most cases to see if you can adapt or settle into that factory seat. Give it a chance although your butt may be somewhat sore or uncomfortable for the first few outings.
Anyway... ride before you buy. And if you're able.. ride again before you make that final decision.
I still stand by what I posted with the understanding that extremely light-weight racing-style bicycles would most likely not be good choices. Correct fit is really important and I'll add that a well-known reputable brand of bike would also be important. Your bike dealer should be able to suggest a few good choices within whatever you've established for your bike budget.
Thanks, I think I’ve narrowed it down to the Trek Electra line, either their Townie line or Cruiser line if I buy new. Probably one of the below if available by spring.
https://electra.trekbikes.com/us/en...wnie-7d-step-over/p/28079/?colorCode=bluedark
https://electra.trekbikes.com/us/en...wnie-7d-eq-step-over/p/28070/?colorCode=black
https://electra.trekbikes.com/us/en...iser-7d-step-over/p/35598/?colorCode=bluedark
I do think they would look great with some wide whites, but I’d have to wait anyway :mrgreen:
Thanks,I have experimented with seat height in the stationary at my gym and my rear is still sore, despite having bit doing this for the 3rd full week now, that could just be that seat and increasing lack of natural padding on my “end” ;-)
Accessories wise, I would definitely go somewhat minimal to start, like a helmet and lock, but not sure what to do on the hydration side yet as it never even crossed my mind, so that is something I will need to research too. I had wondered about a different seats but would give the stocker a test first. Funny thing though was not so much at swapping out the seat, I had been thinking about tires instead, swapping the black wall tires out for some wide whites on the ones above that I was looking at…..think that all three would look better like that…..8)
And I found the wide whites too!
https://electra.trekbikes.com/us/en...6-cruiser-tire/p/12721/?colorCode=black_white
I love my townie its so comfortable and easy to ride the flat foot tec is game changing I have really short legs and I can keep the seat low and still get full extension when i peddle other bikes the seat is ether way to high or my legs are always bent when peddling
my 1959 adultrike is the same way but that thing is about 100lbs and you have to be a indurance rider to make it around the block lol
Always fun to change out tires from time to time and easy enough to do. Closeouts/ clearance tires are sometimes priced to move and will allow you to experiment around with different treads, compounds, and widths. Helmet is a good idea for sure. Comfort is key here although any helmet should not feel like a worn-in baseball cap. You want the ideal middle of the spectrum between too tight and too loose. With chin-strap properly adjusted, the helmet should feel securely around your head. Your head should not rattle around inside. Most helmets also come with adhesive-backed pads that you can place wherever you feel the need for a little extra comfort.
One thing to keep in mind with CamelBaks and other body-mounted hydration systems is that they need to be kept clean/ bacteria-free and depending on the system, that can eventually be a bit of a pain to maintain. I like bottles for the ease of cleaning and the ability to quickly pop in the freezer for a few minutes before a ride. Many different types of bottles out there from small and cheap to larger/ insulated, etc.
Seats also come in just about any shape, size, style, etc. I would advise steering clear of seat pads as many can/ will shift as you ride and can actually become a safety issue if they come completely loose... which happens as elastic wears and the materials/ stitching age. The right choice for you is likely somewhere in between the super plush wide-booty type and the slim lo-profile racing type.
Sore rear end. Yes until your body gets adjust to it.
Yes as mentioned above. Get the correct size seat for your body. Shops can measure that for you.
Padded shorts help a lot.
Pedal forward all the way. Even a bike equipped with a Shimano Nexus 3speed setup is worthwhile. Alot less maintenance and weight than a derailleur setup.
Be aware though, that you'll find the coolest bikes are pedal forward and you'll fall down the collector hole. My bike is a Nirve Cannibal with Corey Miller graphics. I'm 6'4 and it's comfy as to ride.
Sent from my SM-G781B using Tapatalk
