mike
i think this might work if you secured the ends to the out puts?
looks like a dremel shaft those wil take HUGE amounts of torgue, the only problem would be without the outer caseing being held solid it would rotate also if you could make a mount to atache each end of the outer shaft to they would be the idea thing i have seen shafts like those used in motor powered roller skates and to drive scooters and thats whats inside of most weedeater s going from the engine to the trimmer headFrkan said:if you found a way to secure them, in theory, they would work. too much tourqe may rip the metal cables from their monts or something though.
mike said:im probly going to try this on my tlt. if i can get the right lengths, and ends.
Speedo cable will snap fast have the scar to prove itmike said:ya i saw that. i will probly build it out of a old spedometer cable or something like that.
triaxmaster said:Speedo cable will snap fast have the scar to prove it
tried to use it as a makeshife dremel shaft
raptorman57 said:It was asked earlier but what are ya'll gonna do about a slip joint. Unless your links are set up exactly perfect so the shaft does not get longer or shorter these ideas won't work,I wouldn't think anyway. Seems that without a slip it would bind up somewhere.
mike said:it wont have a slip it will have some extra slack, so it will work. hopfully![]()
raptorman57 said:Well,good luck to ya,hope it works for ya.
My steel shafts were to easy to build to fool with something like that. They've got 2" of slip,but only use about 1/2" at most. 1/4" wobblies,1/4"allen wrenches,1/4"deepwells and some 1/2" tube and your set. Bomb proof shafts.
mike said:if you were anything like me you wouldn't be building what everyone else builds. i try to come up with new ideas to improve our rc crawling sport.![]()
