Here is a front end I just completed. I don't know if it will be rigid enough for a road use CRF50 motor'd rig. What do you guys think? Top speed will probably be around 45mph
'03 Marzocchi Super Pro
custom wheel
shinko 244 DOT tire
Hayes stroker 8" rotor brakes?
For the wheel I laced a 17" motorcycle rim into a Marzocchi 20mm front hub with 10ga stainless motorcycle spokes. I did have to drill both the hub for spoke clearance, and rim for the nipples. For the rim strip I used a MR Tuffy liner for bike use. Perfect! Pumped it up to 33psi and it rides very solid on my street bike (bicycle).
My concern is that the fork will be a bit flexy under hard breaking. Total vehicle weight will probably be 150, and I weigh 150lbs. The stanchions are 32mm from top to bottom.
custom wheel
shinko 244 DOT tire
