Futaba 4PL Setup, Tips, Tricks & Help
Thank you Josh and Jason for your hard work on this radio system, just placed my order. "thumbsup""thumbsup"
"thumbsup" Good to hear Steven. You will not be disappointed.
Josh and I have put a lot of work into this but I am really happy with the end result (after the update:roll:)
Futaba is listening and working hard to meet the crawlers needs.
J
So has the lowest button on the radio now become pointless ? after the update is done can you still use that button ? If so would it still have to cycle from center to rear to front ?
With Futaba radios you can program buttons to do many things. It is still used for the pre-programmed 4WS mixing. You can also set it up to control a program mix as well. Those are a couple options.
The programming to allow the dig switch to function that way. In turn this has allowed the use of the pre-programmed 4WS mixing to be used at the same time as the dual ESC mixing as well.
That's the sweet news I was looking for. Guess I'll be sending it in for the updates but oh well, NO turning back now.
First off great video. My question is can I setup a button that I can press and will take my rear motor back to 100% so I don't have to cycle back up to 100%? thank u
In the End Of your Video you showed Dialing down the Rear Esc, When you Dial down say 20% and then Dig does it reset the 20% or does it remember were it was
I hope that makes sence
It remembers where it was.
Just to touch o this so if you leave it ar 70% when you go back and forth until you take the rear back to 100% it will stay at 70% even on allwheel as well as just rear dig correct?:mrgreen:
Correct. You have to tell it what to do, it won't override what you say to do.
Dam and all this time I thought it was going to voice activated :lmao::lmao:"thumbsup"
Well I just got word from a little birdie new years is going to be a really good new years one big gift with 4 little ones wooohoooo :mrgreen::mrgreen:
