AreCee
Hi Harley. Any thoughts about LED lights with the 4PL? Heard from Axial about testing their NVS?
I have the NVS system hooked up to my 4pl. Works fine. Soon as the radio is powered on, the lights come on. You have to use a CCBec or its own battery. You cant power the NVS off the TX.
Well thank you very much.Yes sir.. I even plugged in the extra lights as I dont use a few right now and everythinbg works fine.
Just to keep all the 4PL stuff in one place, I'll add the following here.... http://www.rccrawler.com/forum/electronics/344028-novak-m2-dig-esc-futaba-4pl-programming.html
:roll:
[not sure why the OP didn't do it....;-)]
Hi, I've searched aöready but not found anything and reading through all 85 pages of this thread is a bit too much. I am considering purchasing the 4PL for my scalers (2 SCX10s and a CR-01) and am not sure if this can control a servo for shifting the 3-speed transmission on Ch3 and operate a winch on Ch4. If this radio can do this then I'll order immediately.
Thanks for your help.
Yes, that's very easy. If you need step by step directions I'll be happy to post them for you.
That you, that would be great! I've ordered the radio and already received shipment notification. Now its up to the USPS and the ever fast German Customs.
Until then.
Further down the page you linked, it shows..... TowerHobbies.com | FUTM1832 Futaba HBC3B(4) 4PK 4PKS Charger :roll:;-)Does any one have a part number or model for the 120v wall transformer that will plug into the 4pl and charge this battery? FUTM1473
It does not state if it will work through your TX charge port. Maybe Harley will chime in.8)
Why not just use your existing charger (for your rig packs) to charge the TX pack?? Saves ~$32 and 1 less charger to keep track of?"thumbsup""thumbsup"
The linked charger is for the 4pk, it may work, but the tx port is labeled 4.8v and that one is 6v.
Thanks Harley for the post. I wasn't sure, I was hoping you or others would chime in."thumbsup""thumbsup"That is the correct charger for the battery.
