Star holding members only, giveaway ends 7/25/15. Post ONCE to enter, tell us what you would install the motor into!
Up for grabs is any style of Puller Pro BL motor. Stubby, 540, XL? Anything you want! We will even have 2200kv Stubby versions before the giveaway is done, for you folks with lighter scale rigs that can't handle the abuse our regular ones dish out.
Don't want to wait? We have inventory of all models ready to ship.
The Puller Pro is our latest product line that is based around sensored 4 pole technology. Each version is carefully designed and tuned for superb low speed control and ballistic power. The Stubby and 540 versions have the finest low speed control, but are just as comfortable in your high speed basher as your trail rig. The XL version gives up a bit of startup finesse for higher torque, designed to push around the heaviest rock racers without breaking a sweat. Drop in Yeti overkill! Whatever you choose, be ready for action!
Features:
Four pole Rotor, 200C rated magnet grade
Twelve slot stator, 180C rated wire and epoxy
Pre-installed phase wires with 4mm gold-plated bullets
Oversized bearings, ABEC 5
Sensored
Includes sensor wire
Minimally vented can
Specs:
25mm mount pattern
M3 mounting screws
36mm diameter
50,000 rpm max
Features:
Sensored
Specs:
25mm mount pattern
M3 mounting screws
36mm diameter
50,000 rpm max
