I have a Injora Rock Buggy and the UtB18, I like that tube chassis look and both the Rock Buggy and UtB18 are good crawlers. Do I decided to turn the TRX4m Defender into a Tarantula. Finally got around to putting the chassis together today. The instructions are just pictures but pretty easy to follow if you've done any building. The plastic seems a little on the soft side so one needs to be careful when tightening the screws. Started with the right side frame and installed all the cross members. I then joined the left side frame to the right, leaving the screws a little loose to make it easier to get the skid plate installed.
Both sides of the frame all put together.
The running gear all ready to have the frame dropped on it.
The completed roller. Started with the shocks in the middle hole but I think the springs are to stiff for the weight of the Tarantula so I ordered some softer ones to see how much difference it makes.
I used the TRX4m battery tray as it keeps the battery low to help with the CG. I'm going to use the Injora MB100 esc. I weighted both the battery and the MB100 with the wiring. The battery came in at 36g the esc at 22g so I think I'm going to try installing the esc on the rear tray. I guessing I'll need to add some brass to the front to get some decent weight bias.
