What do you mean "this did not work"? What settings from the above menu did you actually set to?
*This Remote Hack Works Great And I Am Not Bashing It In Any Way!*
Operator Error
The mentioned steps did not do what i expected/wanted them to do. It shows the change from -100 0 100 on my remote. I set that to both the d/r switch and ch3 trim switch on non momentary. Somehow the switch set to control the servo does not control the servo in port 3 on my stock rx. whats weird is when i pill the trigger on my remote the servo spins both fwd and rev with the trigger as the motor spins as well.Several other settings are off or wrong somewhere and I honestly just dont care to do any more learning about this to figure it out.
And your right. It looks like I am impatient, lazy and plain annoyed and not retarded. :|
Bottom line is this is not the remote for me.
Anyone want to trade for a dx3e without the rx for the 3ch rx, remote, program card, 3 extra L Pin things(haha) to do more remotes
ok have the boat up and running the way i like to. Now i want to trigger a relay from the receiver on ch4 using the "C" channel 3 button. Any help will require further assistance im sure, but i really appreciate what you are doing
I have a gt3b hacked controller, I want to set up a winch.can somebody point me in the right direction oh how to set it up? Thank you
Quick question. Does the factory-stock gt3b has a momentary 3rd channel? And does it have adjustable trims? Or do I need to reflash the firmware to have these capabilities?
Fed up with my dx3e.. trim and radio interference issues trying to get this winch to work reliably have got me ready to toss it.
if you mean a 3 pos switch then no it only has a 2 pos switch so like you said it would need flashed software so you can change it
Um, yea
If i remember correctly, plug in your current controller, click read --> all tabs
Then unplug that radio and plug in the new one then press program --> all tabs
You may have to save the data you read, close out of stvp, and then open it up....but this may be tricky i can't remember, its been along time since i've saved/transferred settings.
Just a quick tip.
When you are installing the the voltage regulator and you don`t want to damage your case using a screw driver to split the top from the bottom.
A wooden ice cream stick that has been filed down to the width of a screw driver works a treat.
so i tried this, and no worky...
i tried both ways you suggested, made sure both the radios were running the same firmware, and i forget now exactly what the program said but it started updating but then ends with an error reading. at least i didnt like erase everything and mess it all up.
no big deal but i would still like to know what the proper way to transfer models and settings is since for now im only using the spare gt3b for my gf's rig but would still like to use it as a backup.
