GT3B Hack Question and Answer Thread
Is that trim switch remapped to be a 3 position switch now? I can't wait to get mine now, I've priced it out and I'm looking to save money getting it from overkill, now I just need to save a bit
Sent from my XT907 using Tapatalk 4
Just curious if anyone else this problem it i shut off my transmitter before the truck it will delay a minute and then the truck will begin to start driving. Anything I can do about this? Other than the obvious of shutting the truck off first.
Just curious if anyone else this problem, if I shut off my transmitter before the truck it will delay a minute and then the truck will begin to start driving. Is there anything I can do about this, other than the obvious of, "Shutting the truck off first"??
RC rule #1, "TX on, then rig...... rig off, then TX"....
RC rule #2, "TX on, then rig...... rig off, then TX"....
Repeat............:shock::roll:
Yes, you can usually set a "failsafe", but be smart and don't count on the electronics."thumbsup""thumbsup"
PS..... "No charge edit" of your post for clarity.
So somehow my last cheap Chinese esc I'm using for winch duties (have 2 others with brake, this one is without brakes and I'm thinking this may be part of the issue) is faking the ch3 port into bind mode upon power up. Works fine within the same power cycle, soon as I cycle the power... bind lost. Switch ch1 and ch3, steering works the winch and dual rate switch (mapped ch3 to dual rate with momentary) works the steering. Power cycle multiple times and keeps working in this reversed fashion.
Question: anyone know how to switch ch1 and 3? I've gone into key mapping (long press Rev in 0.6.1) and not happening. So aside from buying an fxr for winch duties, can this work?
So I've been wanting to try this out and I finally have everything needed and ready to go but am having issues figuring this out. I may be overlooking something simple but I've read and looked and can't seem to get it.
Hacking a GTB-3
Has anyone done their own fresh firmware install on one of these lately? I'm having issues getting the new firmware into the st. program to update my Tx.
I'm getting communication back and forth because I'm able to save the original Tx program for a backup but I can't seem to save the hack software in the correct file extension, only in a txt format, and if I go to GitHub I can't import it into the st. program to rewrite my Tx either??.
So I'm not sure where to go from here? It's the first I've done this so I'm sure I'm missing something but can't figure out what.
Any help would be appreciated.
--Dan
Im having some major issues with hacking my buddies GT3B i followed all the steps and have already hacked my own my issue is i plugged in the remote to hack and it made its beeping tones so i knew it was working opened st program loaded the firmware i wanted and then clicked the program tab and current tab loaded it just fine once i unplugged the wire the remote was dead wont turn on nothing tried the procedure again but now when i plug in the remote its dosent come on and beep it does nothing just opens the window showing it as a external drive but the remote is a big paper weight checked to see if the board is getting power and it is changed batteries still nothing please help....... feel bad that i had no problems with mine and iv killed his
Sounds like you programmed abunch of zero's into the radio...do the procedure again (it won't beep this time) and make sure to open the firmware
another problem is the firmware websight is down so where do i get diffrent firmware thought the st program came with it apprently i opened the wrong thing
I tried that one but the st program wants to open a *.s19 file and the file downloads as something els and the st program wont find it, thanks again with all the help
i finally got it to work had to put it on the desk top and open it from there no idea why but turns on now thanks again for the help"thumbsup"
I tried that one but the st program wants to open a *.s19 file and the file downloads as something else and the st program won't find it, thanks again with all the help
I believe in the last page or 2 in this thread, there was the same discussion. You can also just download the file and change the file extension to the correct one, then it worked.
It was dowhloading as a *.man IIRC.
Glad your's is OK now.
Quick question about the gt receivers will they hold up to 7.4 volt usage? I have a pair of d772 servos and a bec and was wanting to turn up the volts to what they are designed for ie 7.4.
Sent from my iPhone in the shop
No, but i got some new ones from flysky the other day that are supposed to hold up to the higher voltage. I haven't had time to test it though (mainly because all my personal radios don't use flysky receivers:oops:...both my 3b and 3c have been converted to frsky)
