First, thanks for all the cool tech info here, thought I'd add back, hope not a duplicate.
I got the Turnigy GTX3 (Flysky GT2B clone) and the expo works fine, and while I will replace the VR as per in this thread, but may not reflash, I first tried to used a $5 DC-DC step up converter regulator to run a 2S1P LiFe RX pack in the transmitter, and it works great! Thought was to use only a 2S LiFe which is plenty, but avoid the low voltage alarm at 9v because I'm not ready to reflash yet.
I took out the 8 cell AA holder, and there is plenty of room for the DC-DC converter and a 1450 Mah LiFe battery. I set the regulator output to 9.2V, which it holds steady as the battery goes down (but LiFe have a pretty flat curve anyway), and I think the low voltage prevents the stock VR from overheating or being too inefficient. Regulator handles input from 3V to 34V and up to 2.5 amps. The GTX3 amp draw is below 0.2 amps.
I.e., light long lasting battery, charge same as the LiFe 6.6V used in your car. I've had everything turned on for 4 hours, and LiFe voltage has dropped from 6.7V to 6.54 volts, while the TX voltage stays solid at 9.2V whole time. Battery, converter and TX screen in VR are all cool, no sign of heat anywhere.
I used the "LM2577 DC-DC Adjustable Step-up Power Converter Module" from Amazon, $5, lol.
Note, if you try this, first use a voltmeter to set the DC output close to 9.5 volts BEFORE hooking it up to TX, mine arrived set at 18 Volts.
