I had the same problem. Here's my post from page 397.Guys,
have a GT3C, the orange model. Been running it for a few months and works great.
But, the other day one of the push-buttons soldered to the board, the one on the "selector-wheel" stopped working. If I pushed the "wheel" hard down it would react but with experience I know that will break something else soon.
Anyway, the selectorwheel works just fine when wheeling left and right, so I de-soldered the END-button on the board and soldered it to the selectorwheel-place instead. Works great.
However, I would like to get the END-button back in order, which means buying a replacement that has the same dimensions so it will fit when soldering it to the tabs on the board.
Anyone have a clue, ebay for example, what I should search for?
Any help appreciated.
N
Solved:
Got PM, found these, thanks:
http://www.ebay.com/itm/10Pcs-Momen...231?pt=LH_DefaultDomain_0&hash=item41936c3427
Can someone help me setup my gt3c for my trailfinder 2 I have no idea how to setup the shift servo and the winch please and thank u
This links to post 1693:Even with the gobs of information in this thread Ihave one hellova time figuring this thing out. I have a hacked GT3B with a 6 channel receiver. I have channel 3 set to run rear steer (barely figured out how to do that) and the ch3 toggle button set to switch between full and crab.
Now I have a winch on this rig in channel 4 and want to run that with the GT3B. How do I get that to work as well?
heyok, to set the END button to control ch4 as a -100,100 momentary do this
Long click REV
scroll to E, enter
Scroll to CH4, enter
MO0
RE0
PV0
If you want it 0,100 it needs to be PV1, if you want -100,0 you want RE1 and PV1
The ch 5 winch
Is
Long click REV
Scroll to 1, enter
scroll to ch5, enter
scroll to BMO, Long enter
Thanks for the swift response. I believe I followed this to the letter but still no winch action. I plugged the winch into ch1 just to confirm it actually functions, it does. Oh well.
Things to check:
Are you on the same firmware? That procedure is for 0.6.1
Do you have the model set for the number of channels required? I think it defaults to three unless you have changed it.
Long click REV
scroll to E, enter
MO0
RE0
PV0
The ch 5 winch
Is
Long click REV
Scroll to 1, enter
