GT3B Hack Question and Answer Thread
Ok so lets see, i belive this is all the features in addition to the ones already there.
- ~15 model memory depending how many channels your firmware is
- Sub trims
- copy models
- fixed expo
- Model reset
- Steering speed
- 4WS Mixing
- Dual ESC Mixing
- Dual ESC steering
- Multi Positions Switches (Up to 8 True positions out of a single push button)
- Key Mapping (any key can control any channel in many different ways)
- Calibration Menu
- Key Test Menu
- Backlight on time
- Inactivity Alarm
- Adjustable Low volatge warning
- Adjustable Maximum End Points (Up to 200% i think :shock:
- Adjustable dead zone for steering and throttle
- Turn keep beeps on/off
- Adjustable long press delay
The Trim and d/r keys can do this
- nothing, it is possible to assign each button individually as key
- trim of channel 1/2
- dualrate of steering/forward/back
- expo of steering/forward/back
- change channel "n" value in range -100...100
- subtrim of channel "n"
- 4 wheel steering mix -100...100%
- DIG throttle mix -100...100%
- Multi-POsition, switches position up/down
- steering speed turn 1...100%
- steering speed return 1...100%
They Can be setup to act like this
- momentary, hold left/right trim key to get end values,
when nothing pressed, servo is at centre
- no long keys, long press is the same as short press
- autorepeat is on
- long press of one of trim keys will reset to
centre/reset value
- long press of trim key will set to coresponding end value
And they can have an adjustable step rate, oppisite click reset, reversed, etc.
And the Keys (ch 3 button, back button, end button, and the trims if set individually)
- nothing
- switch channel "n" value from one end value to opposite end
value.
- reset value of channel "n" to centre
- switch crab (CRB) no-crab (NOC) for 4 wheel steering
- switch DIG mix between -100 and 100 (more useable when using
return to previous val key setting)
- Multi-POsition, switches position up (at END back to 1.)
- Multi-Position Reset, switches position to first one
Im having issues flashing the 8ch firmware. everything seems to work fine. when i connect USB it mounts. it opens the firmware,but when i click program current tab i get this
Problem signature:
Problem Event Name: BEX
Application Name: stvp.exe
Application Version: 1.7.2.0
Application Timestamp: 4d5bd56f
Fault Module Name: STLinkUSBDriver.dll
Fault Module Version: 4.2.1.0
Fault Module Timestamp: 4d355df2
Exception Offset: 00001e60
Exception Code: c000000d
Exception Data: 00000000
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Information 1: ba89
Additional Information 2: ba895f3357481fb946e15f020f8a4d05
Additional Information 3: ff3e
Additional Information 4: ff3e00202704d3eb6d72cd19850004ae
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Is your cord plugged in right? Black arrow is on sb1 side on the programmer, and on the button side on the radio
same thing. i click program/ current tab and it crashes. Im guessing its normal for the low batt beep to come on because the radio is turned off and its powerd by only USB? is there something else i need to do to the radio? all Ive done is install the program, the driver. plug the programer into the TX then the programer into the PC. open the program. load firmware. crashes on flash
i got my kit yesterday and today did the programming it took a couple trys as the 6ch didnt want to work the first try for somereason but i got mostly figured out, just trying to understand how to set it up the mixing for a moa. but did get it to run my punk dig in my losi moa and running my tamiya semi on it with 4 channels.
losikid can the esc mixing for a moa be done with a 3ch rx? if not then i guess ill need to order a couple 6ch rxs, just trying to save some $
Hey bud, read your problem over on rct...anyways i was able to simulate your problem.
When changing the amount of ch's but keeping the same firmware version then you have to revert back to an older firmware i used 0.2.0 then load in the new one. I believe this is caused because when programming a 0.3._ firmware over another 0.3._ firmware it will save your models. Well when you change the amount of channels, it changes the amount of max models, and probably some other stuff so it can't overwrite properly which is what causes the it not working. I'm going to consult with psx (the developer) but it did this to me many times, i reflashed my radio like 20 times in the past hour or so. I'm pretty sure thats the problem.
See post above for link to the 0.2.0 firmware so it can be reverted back then back to 0.3.2
Is the program crashing or just a error log coming up in command prompt ?
a prompt pops up telling me the GUI has stoped working. asked to close the program or check for solution online. running windows 7.
Thanks for the help
Thanks for the help
huh, strange.
Can you run it an xp or older os compatibly mode? I'm not familiar enough with 7 to know how well it works with stuff not made for it...you may have to try and find a windows 7 driver...are you 32 or 64 bit?
huh, strange.
Just tried compatibility mode with no luck, already tried as administrator and that didn't help. Its W7 32bit. Ill keep sifting through the RCtech thread. it crashes when I try to program so maybe its something on the programer side.
Snapped of the other half. Didn't work. I uninstalled the software. Just rebooting now and will reinstall
