Hi All from Australia.
H2Micr0 here.
As a young fella I always wanted a radio controlled car, but life at that time didn't allow for luxuries of that sort. Now I am on the more mature side of life I am in a much better position to indulge.
I discovered RC Rock Crawling on You Tube earlier this year and was enthralled by what these scale RC trucks could do. So a few months later I purchased an RTR SCX10 Honcho.
Out of the box was a lot of fun and quite capable, as you all know.
One week after purchase I 'upgraded' to some cheap ebay plastic beadlocks, and a set of Pit Bull Rock Beasts. I also discovered how easy the factory plastic four links, and steering, bend under load, and using some 4mm all-thread, aluminium tubing and RC4WD ball ends, made my own links. I also removed some of the Axial stickers.
The plastic beadlock rims were really poor quality and the screws were stripping easily, so I ordered some cheap chinese alloy wheels from Ebay. I also purchased some cheap Topcad 110mm shocks from a local seller.
I attended my first comp and after the first run I heeded advice given and quickly removed the factory rock sliders and cut down the Honcho front bar. Second run went much better and the bug had bitten.
I was lucky enough to have been given a used set of the R1 Gmade Portal differentials a new mate after I helped him out with a ride and a fix on his rig at the comp. I was able to mock them up before I headed to the USA for 2 months.
Using the Topcad shocks, with the SCX10 springs I was quite surprised at the articulation I could achieve.
After much research I went ahead and purchased some new R1 Gmade differentials and the alloy upgrade parts to go with them, including the 8 degree castor hubs and CVD front axles. I also ordered some Junfac drive shafts.
Arriving back from the USA on May 18 I attended the May 19 comp. I ran the R1 differentials my mate had given me, as I didn't have time to assemble the new ones before the comp, and unfortunately, my Axial 27T motor went up in smoke. Luckily I had acquired a cheap spare Novak 35T motor, along with some other goodies, while in the USA, and after I got home was able to get the truck back up and running. During the comp I discovered I REALLY needed to improve the steering, and the Pitbull's stock foams were useless if you wanted to turn.
With the Nationals fast approaching I got to work.
I customised the Honcho body, built a rear tray to suit, adjusted the wheel base and built new links for the suspension. I was able to improve the turning circle quite a bit, and sorted the Pitbull's sad turning circle by inserting some cut down tire sides and stock base inner foams. I had previously fabbed up some battery trays, and am running two 3300mah 2s lipos in parallel. I still have a lot of work to do to tidy up the wiring etc, but with plans for the future of the this truck, it can wait. I was able to pick up some sweet Mayhem Engineering Crazy 8 alloy wheels, with Putbull tires off TCP for a good price and they finish the whole lot off nicely.
Enough chatter, some pics.
Future plans include a complete rebody with this.
I have many questions on a number of different topics, which I hope all you very knowledgeable fellow enthusiasts will be able to help me with.
Please feel free to comment and offer suggestions and advice.
Here are a couple of pics with the Honcho in Trail Run mode at Lake Parramatta on a shake down run.
Cheers
H2Micr0
H2Micr0 here.
Cheers
H2Micr0
