ctrwannabe
3s max on the puller. If you run 4s is will wear out fast.
Sounds like you killed the magnets, you need a new can.
do you have 7t cans in stock, pp ready "thumbsup"
Thanks for the info. I forgot to ask about run times, I know gearing will have a large impact on run times, but will 1300 lipo last the same as a 1500 nimh. Are run times long with the lipos for the same mah. When will you have more FX-R esc in? Thanks again for you help!!
JOHN, i gotta say THANKS!! for all of the customer support, any news on that cobalt bearing? looking foward to using it at the comp. let me know what i owe you for repairs, shipping. etc.
Have you recieved my email about order # 2984 (Exchange/Refund defective Hyperion Charger). bi_eep@yahoo.com
Thanks John. I feel confident your just really busy because your support has always been good.
where the 35 and 45 turn's![]()
JRH...just getting back into crawling and dusting off the old clodbuster with 55t lathes. Currently running 8t pinions and a single Sidewinder with a Castle BEC, planning to upgrade to another Sidewinder for independent motor control in the near future. I'm using the Hitec 805 servo's front and rear.
1) What size (mah) 3s lipo pack would you recommend?
2) Do I need another BEC, or will one handle these servo's at 6+ volts?
3) Should I drop down to 7t or 6t pinions to take advantage of the increased voltage? I was running the truck on 6c 3300 packs:|
4) Recommend a charger with a built in power supply around $150.
Thanks.
Hey jrh, any news as to the release date for your esc. I am seriously in the market and am patiently waiting. I need several so please keep me updated
Sent the charger off today. Thanks for the lightning quick response. Customer service is always fantastic with you.
John R Holmes is DA MAN!
I have been trying to get some more info on you new ESC "TorqueMaster BR-XL".
Is the built in BEC good enough for a strong servo (400oz) or will I still need a CC BEC? Also what is the motor limit?
I also have another question that I have not been able to find, Can the Tekin FX-R run your Cobalt puller 7t? Or if I could find what the Cobalt 7t translates into for 540 size turns.
Thanks for any info.
