Hillbilly's garage
Haven't been able to tinker lately been busy, collected more parts for more projects lol.
Got one of the injora capra style cages and pairing it with some metal capra style axles. Still need other parts but it's a down the road project.
Picked up some scx10 style rails on plans to redo the cab swapped barrage but changed my mind. Going to just finish it how it is.
Scx10 chassis will now be a Tamiya f350 based rig. I have axles already for it but basically it.
Still trying to get my electronics figured out when I get time for the Ascent sleeper (g-speed clone with ascent cab)
Ascent sleeper is getting closer, my OG 1080 I was going to use for it isn't working, tried a different motor and tx/rx combos with it can't figure it out at the moment. So I just picked up a hobby wing fusion se 1800. Found my ascent bumper mounts and bumpers. Some front chassis trim and some shaving of the bumper mount. Then a battery mount and I'm done.
Here is my thought with the f350. Cross tube bed fits the back profile of the cab. This way I won't be stuck running the bed and 11.4" wb. Tube bed is left over from the top piece I used on SE trail truck.
Installed the hw 1800kv 2n1, and chopped the front of the chassis off, after I modified the Ascent bumper mount to sit flat on the chassis and made sure it wouldn't interfere with the servo. I painted the body today and tossed couple decals on it. Still need to fill shocks but it's 99% done. Even took it for a tiny test drive as well.
Took the boys out earlier today to play with their crawlers. Didn't take any pictures but they had fun.
Tinkered with the intheworks utb18, installed a new servo mount with a battery mount. Fitting a battery is tough with the space available. Had to move the front shocks back for servo clearance. Used the shock keys that I took off of the ifs mullet when I installed the exp shock towers. Had I drill a new hole cause only one hole lined up. Now I have multiple shock mounting in front for future tuning.
What wheel base can you get with the combo? have you tried the sendero back cage? I have the f350 cab also I’m trying to mount to a GK. I’m stuck on mounting and what to do with a/the bed. I still want the trailing arms so I’m stuck at the 12.8wb. Wish I had the time to bend a simple one myself.
Edit: I might have actually found my answer and the price is right.
I was planning to run a 12.3" wb. So a 12.8" wb should work, only thing if you were to use the Cross bed would be the shock towers possibly interfering with cage. I haven't really thought about that project yet. Besides thinking of a tire size and paint scheme. Was thinking retired Forest service truck turned into a dedicated wheeler.
Did some tire/ wheel combo swapping last night.
Tsl/ roosts combo with vanquish dual stages went on the ifs mullet, will have to see it does since the combo is much lighter than the Treal wheels.
The SE got the Treal/vanquish geolanders with some injora silicone inserts. Heavy combo with the silicones and steel inner ring of the Treal. Found some pin holes in the geolanders when swapping inserts on I believe the two fronts. So will need to address that. Tire/insert/wheel combo gave it an aired down look.
I'll get pics up later.
Swapped over to the brass wheel hubs and I recently got some scale hardware so I took the chance to swap those in too.
Also started to put the Barracho back together/ plan the rebuild finish of it. Need new wheels and tires since I stole them for the yota utb18. Fix the front links as it was set up for 3 link and CMS and now has SOA so 4 link it will be. Unless the new Front motor mount gets in the way. I picked up a clone fmm and creeper T as well as front and rear shock towers from TGH in carbon fiber. The fronts I'll have to make an adapter tab to mount the front of the tower so the tower isn't pitched weird and throw off the fmm in a odd angle. All in due time.
Here is what the state of the Barracho looks like at the moment. Kinda of a slider but missing parts. Wheels and tires are for Mom's spaghetti. Which I need to swap the black beadlock rings to silver ones I have. But a 4.19-4.30" tire is my goal. The tires on the wheels are Vanquish 1.9 Falken WILDPEAK R/Ts.
I ordered a some tires and wheels for the Barracho. Went cheap it'll be a trail truck not a rock crawler. Found some 4.19 fake hyrax and likes the multi spoke of the beadlocks I took off so found another wheel I liked. Still debating a chassis swap as well. Have some scx10 rails but will need to be shortened for the wheelbase.
The f350 I did buy a chassis for it. I was debating it and with shrink rc mounts I decided on a vs410 rails and will piece something together with it as a base. Plus been wanting a vanquish based rig.
Debating which axles to use under the vs410 f350.
This set i had bought for the scx10 that became the "birthday brat" also thought about using them under the Barracho.
These are a capra style clone and have a BTA servo mount for it. Which I originally bought for the injora capra style cage.
After seeing Harley's (josh) flip that truck season 2 episode 1 of the vs410 with capra style axles. Think it would be a fun truck to build with capras plus I have a couple tiny portal transmissions as options since I got the 3 gear skid with my chassis and not the VFD skid.
Girl's son is in marching band and we had to go out to the coast cause he is in the parade again this year.
So we left early and hit up Beard's hollow cove for a couple of hours before heading into town. Super fun and weather was a tad cold but nice.
Was going to tire test with the Mullet then bolted up the tusks with single stage proline tsl foams in the front and stock jconcepts in the rear. Only tires I tested cause it just great.
Realized I was kinda heavy with Ford bodies for much of the garage. A little while ago I found a 3d printed body from a guy on Etsy the first one I found had front fenders. This one I bought does not have fenders. I'll be putting it on my mullet once it's here and I get it painted. Patina tan and blue is my thought.
Finally got the last chassis parts so far to start mocking up the vsf350, which were shock towers and body mount kit from shrinkrc. Also got a free set of proline g8 grunts that is perfect height at 4.4" from canyon crawler on YouTube.
I'm looking for a military-ish beadlock for this build. Any suggestions would be appreciated. I've found a couple but nothing that screams at me yet. Maybe some cheap beadlocks and different beadlock rings. Below is what I've found so far. I'll paint the wheels either tan or OD green to go with the paint I choose.
More looking i found these, only thing is they don't have removable hubs. So any width adjustments would have to be done with hexes. Which might work out since the capra style axles is what I'm leaning towards.
