Holmes Hobbies Motor Help
clickaus
Geelong
Hi guys
I just bought a new Holmes Hobbies 27t Expert motor.
My question is the motor has 4 tabs on it and I don't know why.
I thought a motor only has 2 wires running to it so I am not sure where to solder.
Any help advice where to solder would be great
Motor has 4 tabs, but are continuous on each side! Look at the tabs down near the can two will be touching each other & the other two will do the same. Positive & negative on brushed motors can be reversed so I'd will work either way but throttle may be reversed on remote or swap positive negative around.
Thanks for the info mate.
I just soldered the wires on and everything worked out :).
Finally the truck is back going again
