Hot Racing Drive shafts
Truckmechanic304
Charleston
I have HR drive shafts, part# SSCX37v, I am trying to find out what pin they use. I tried my stock ones but that wasn't it, anyone have a solution to this?
The stock pins are too large in diameter and they are threaded for plastic. The HR has a fine machine thread.
The stock screw pins for the drivehaft should be M3 (AXA0175) or M4 (AXA0286, HD Wild Bore) machine thread with a 2.5mm dia. shaft depending on which driveshaft is being used. It sounds like you may need the M3 screw pins, Axial #AXA0175.
That 4mm sounds about what my stock one is. I'm gonna fine a M3 in my extra scenes and see if it works, thank you!
