BigB_117
I'm swapping out my knuckles, but the bearings are in there pretty tight and I dont want to break something...
Thanks. "thumbsup"
Thanks. "thumbsup"
Mine were tight also. I used a small punch and lightly tap them out. You shouldn't damage anything as long as you don't get to crazy.
The Axial aluminum replacement ones.
hope you have the axial top hat bushing for them.. the berg ones won't work.!!
The little brass guys?
They seem to fit...
yes, they are too short. when you tighten the screws it will bind knuckle. don't feel bad, bryan forgot to tell me too
I used a stub shaft and pulled it out with a little leverage force... just push it to the side a little when pulling them out... worked like a champ...
Just get new bearings, the stock Berg ones suck.
The stock bearings are just about the same quality as most bearings out there. Not sure why they would be described as "suck." They may not be top end, but good enough for crawling from my experience.
