Ok I've been meaning to do this for some time. This is a pretty simple item anyone can do it. Plus it gives that much more of the scale look to your rig.
Here are the items you will need. The wire can be found at Lowes or Wal-Mart for under $2 bucks.
Step 1:
Cut the wire about this length. Doesn't have to be perfect.
Step 2:
Rap Place the wire on the Small Screw driver. Like So.
Step 3 and 4:
Rap the wire around the screw driver a few times. Make sure to leave enough wire for the Hook and the end.
Step 5 and 6:
make your hook like so.
Step 7:
When your done it with this part. It should look like this.
Step 8:
Do that two times. Need hooks and both ends right.... Cut the length you need the cords to be.
Step 9:
You will need to tie a knot in both ends of the cord. Make the knots close to the end of the cord.
Step 10:
Slide the cord with the knot into the hook. Just enough to hide the knot.
Step 11:
Now smash the last loop on the bottom of the Hook. This keeps it from pulling out easy.
Step 12:
Now cut the extra off the Hooks and your Done.. If you did it right. It should look like this.
Step 1:
Step 2:
Step 3 and 4:
Step 5 and 6:
Step 7:
Step 8:
Step 9:
Step 10:
Step 11:
Step 12:
