With the 3rd annual Crutis Bautista Jr. Memorial TTC coming up & everyone worried about rules, I thought I'd post some up.
These are for all classes
1. NO comp crawlers.
2. NO MOA axles, MUST have only 1 frame/skid mounted motor & driveshafts.
3. NO cut-n-shut tires.
4. NO hand of god. H.O.G.=DQ for the course.
5. NO tire changes. What you start with, you must finish with.
6. Tire height limited only to what is available from the manufactures.
7. MUST use scale tires, NO comp tires.
8. YOU MUST HAVE FUN!
The goal of this event is to bring SCALE rigs & have fun.
Tough Truck Class
• Description - An off-road vehicle that you would " DRIVE " on the street or to the trail head
• 4.75" max tire size with a max rim size of 1.9"
• No wheelbase limit- wheelbase must 'fit' vehicle concept/body.
• No max track width.
• You may modify any tire that is not on the banned list. You may NOT cut-N-shut.
• You must run a complete body, including bumpers, fenders, doors & tailgates. Some fender trimming is allowed but the basic shape must be retained, Fenders may be cut, or flat fendered, but it must resemble a 1:1 rig you'd see on the street. If you remove the tailgate, you must have a complete floor and drop bed. If you want to remove your doors, you must run a full interior.
• A shortened or lengthened body is allowable. A tubed bed is fine(rear fender and tailgate rules do not apply to tubed beds).
• No 4 wheel steer or rear steer at all ! If you have more than 2 axles, the FRONT axles are the ONLY ones that can steer.
• No MOA axles of any kind.
• Single engine rigs only.
• Wheelbase is limited only by your body, and must fit in your fender wells.
• Vehicle must have a frame-railed chassis. Tubed frame rails are ok.
• Vehicle battery must be mounted on the chassis. You CANNOT mount the battery ON the steering servo/axle/upper links. The goal is to place the battery where it is not visible for a more scale appearance.
Top Truck Class
• Description - An off-road vehicle that you would " TRAILER " to the trail head
• 5.75" max tire size with a max rim size of 2.2" You may run 1.9" if you choose. No cut-N-shut
• No wheelbase maximum- wheelbase must 'fit' truck concept/body.
• You may modify any tire that is NOT on the banned list.
• You must run a complete body, including bumpers, fenders, doors & tailgates. Some fender trimming is allowed but the basic shape must be retained, Fenders may be cut, or flat fendered, but it must resemble a 1:1 rig you'd see on the trail.
• 4 wheel steer & dig allowed.
" TUBERS " If you plan to run a tuber in EITHER class, here is what you need to know. It must have a full interior, 2 front seats SIDE BY SIDE, a dash, a steering wheel, a hood panel, a roof panel and a left and right side panel. If it is a jeep, it needs to resemble a jeep. The minimum size for the tubers is as follows:
Height 5 " , measured from bottom of skid pan to the roof top
Width 5 " , measured from the middle of the door bars, side to side
length, your chassis needs to be ATLEAST as long as your wheelbase, measured with the front tires pointed straight and the vehicle at rest.
NOTE: this does not apply if you have a truggy or back halfed truck with a conventional frame and cab.
BOTH CLASSES, NO COMP OR TVP CHASSIS, NO FRAME EXTENSIONS TO MAKE IT SCALE EITHER, PERIOD. THIS IS A SCALE EVENT GUYS. Example of these chassis are: SWX, J2-TT, GC-2, edge, eclipse, hustler, etc....
Banned Tire List:
• Losi Claws and Comp Claws
• Imex red rocks, rubicons, truck pulls, skulls and bones
• Hot Bodies Rovers and Sedonas
• HPI Rock Grabbers
• All Panther Tires
• All Jconcepts Tires
• Full-width Mashers, narrowed are OK, no wider than 1.75".
• Pro-Line Chisels and Badlands
• RC4WD Rocklins, Crazy crawlers and X-locks
• Any on-road, buggy tires or truck racing type tire
• Non listed tires must be judged and we reserve the right to modify this list as new comp tires are released.
Tough Truck Class
Top Truck Class
Banned Tire List:
• HPI Rock Grabbers
• All Panther Tires
