---Idk----my machine---IDK----
The steering upgrade would be sweet! Tho I'm throwing steering with a xr-10.. I just want to find a way to put The universal steering axles in or find some MIP axle shafts.. even if I have to grind the ends to match length.. ur rigs looking sweeettt with that tuber on it an 4ws! Good stuff.... Broken axle shaft, no fun! Just replaced one of mine yesterday.. as far as shocks... Man, 130mm sounds huge! I just helped a fellow creeper out with his rig an forgot how tall 120mm was.. I couldn't imagine.. ill be waiting for pics to check it tho!
they would be inverted they are intery shocks the interal spring ones. i thought they would be but was thinking if i ran them in a droop setup as i am now i might be cool. think ill just got with the HR air shocks instead. thanks winnerone23 4ws is off right now can decide if its coming back
ok so i didnt really research these but got some berg alum 3 spoke rims. ive looked through the search and see that people have put them on creeper axles but not if it needs wideners or what? anyone have clue?
Lol, I run Berg offset ckrc "skinny" wheels.. they don't clear the front knuckles without wideners.. I bought a HR multi- wheel widenr kit an only had to use the 5mm wideners out of the kit.. had to custom grind the hex slot in the creeper hex to fit the slats on the wideners.. I can send a pic later or check out my thread, there are pics.. it also depends on how wide ur wheels are.. if there thicker, you may need the 10mm or you may go with 15mm.. this is just how I did it..
eh, wish i would have looked into more. oh well they were cheap and my stocks are stripped anyway so i get what i get
cvd!!!!why must you die when im having fun:( oh well so do they not make xvd for the creeper anymore? or can i use the ax10? version. i keep breaking front one not the rears. also im going to be dumping the tuber for either the gmade stealth cause it looks cool or the rdmw chassis. havent decided but rear steer is gone either way. gonna keep the tuber and make it into something else. but as of right now ive had it with that damn thing. wish i still had the stock chassis but i hate bodys so what can ya do. new parts here i come!!!!!
I don't believe they make the xvd anymore an there hard to find, I have looked.. I was hoping to find some MIPS but it seems they dint make them either.. was hoping cause of how thick they are to cut an grind some to work.. can't really find them either.. Thomas, Rmdw, says to be patient he is working on something to take care of this problem we all have!.. not sure on the ax either..
As far as chassis go, I enjoy the Heck out of my xrv2 chassis! An the new chassis, slant, from Rmdw looks awesome! Big thumbs up for Rmdw chassis!
okay well the ax10 axials wont work as they use a same length axle for both sides were we use 2 different length axles. the plan that RMDW is thinking of is how easy and or is it possible to take the universal axle set that they have for the xr10 and the wraith and make it work in te creeper.
for chassis sake, go with the RMDW one. i abuse the snot out of mine and she still goes strong. the only problem ive had is the lower link mounting points bending but i think RMDW had made a change to the chassis design and make a stiffener kit to stop that from happening.
I have the chassis stiffener kit.. stopped the bending the second I put them on! It's sweet! I beat the piss out of mine as well!
ok im going through to many cvd. im wondering if i have to much steering? can someone give me a little input. here is my max to both sides
157 by rev_woode, on Flickr
158 by rev_woode, on Flickr
i rub alittle on the springs but its not that noticable. any input is helpful
woot woot i just won me a new tranny and dig unit for 20 bones on ebay!! question were do i mount the servo for the dig? for the time being im running the intergy tube chassis but i will be switchin to the rdmw chassis soon. and also it comes with a servo im assuming is the stock one from creeper. i have a hitec hs81 is this servo enough to move the dig easy enough?
LOL! Ur lucky lucky! I was dealing with my daughter an by the time I picked the phone back up it had 1 sec left... Good deal! :)
Not sure where to mount it on ur chassis but once you get xrv2 chassis, it mounts to the side of the cab in the rear with stock plastic servo mounts.. well for a full sized servo anyway.. its on page 102 of, the creeper wagon...
