TakeOffYouHoser
Calob started the day in less than optimal condition. A last minute brainstorm invaded my skull last night and needed to be checked. It was sure to work! I knew it would. I felt it would! :shock:
His RTR condition would be crippled to something worse than DNF ... a DNStart, a no show. The culprit? A broken 2.5mm screw. With one twist of the wrist (any moto riders out there? "thumbsup" ) his day was shattered! ****! *******************************&!#(%&(@&$#$%*&@$)%*$@^& I thought to myself, this will NOT happen. I can fix ANYTHING! Or at least MacGyver or hodge-podge it well enough to get going. I know I can. I won't let him down. It's his big day!
A quick inspection of the hardware available showed no 2.5mm stuff in stock. !@(&#(%&(&$@(%&@$%*&!!!!!! Okay, fine, I don't need to worry ... I can, uuhhhhmmm, relocate this ... swap those around ... YES! This WILL work!!! A mad flurry of screwdrivers and wrenches progressed and in no time at all Calob was, again, RTR.
Ladies and Gentlemen, boys and gilrs, children of all ages ... introducing CALOB!!!!!!!!!
<a href="http://s1286.photobucket.com/user/TakeOffYouHoser/media/015_zps2f5dc41c.jpg.html" target="_blank"><img src="http://i1286.photobucket.com/albums/a609/TakeOffYouHoser/015_zps2f5dc41c.jpg" border="0" alt=" photo 015_zps2f5dc41c.jpg"/></a>
Before I get any further I need to thank fellow RCCrawler pelanas for his inspirations ... http://www.rccrawler.com/forum/redcat-rs10/280971-my-new-tracer-chasis-rs10-hbx-rockfighter.html ... and ... http://www.rccrawler.com/forum/redcat-rs10/306523-my-rs10-tracer-brushless-mod.html Without finding those two threads this would not have gone anything like it has. Pelanas - THANK YOU! "thumbsup"
The devil is in the details, right? I got those ... and pics, too! ;-)
Below you can see full rear-only articulation. Yeah, totally rigid front end, as in no suspension. I LOVE this set up! Compared to stock it shows immediate improvement. The ability to mount the battery further forwards and only slightly higher than stock does wonders for front end traction. I can push it further, but for right now it'll work fine. I want to see how it goes before making new arms.
With the front end rigid I no longer need to worry about things like shock clearance and motor wires getting snagged (although in this pic you can see I still need to address that a bit). You can also see the HiTec HS646WP blue box servo that has already replaced the stock unit (what an improvement!). A stock RS10XT tire is used for reference while Calob happily wears his Pro-Line Chisel shoes (with stock RS10XT foams ... the Pro-Line foams were too much pita to mount).
Now the questions might begin. So the battery is mounted against the frame and ... a TURNBUCKLE?!?!??! Yeah, I was going to use the stock shocks and remove the springs and put o-rings to "lockout" the shocks and remove the front suspension, but for the few bucks that the Redcat Volcano turnbuckles cost I let laziness take priority for this article. You might also notice that the lower linkage arm is round, not the stock hex lower and that there is something funky going on with the frame plates and lower tray. Calob, wtf dude?!?!??!
Perhaps a look "under the hood" is in order, yes? Calob, my take on the poor man's Tracer ...
Here you can see with better detail what's going on with the Volcano turnbuckle. You can use the stock shocks and spend a minimal amount of money using *whatever* to lockout the shocks, but I wanted to do this. I prefer the ease of adjustability with the turnbuckles, as opposed to having to screw around with taking apart a shock to re-locate o-rings and such. This is, after, my first crawler and i'm not sure what will wind up where. lol
A different angle of the same thing. If you were to scroll back up to the first pic you would see one other detail you may have missed before - the upper link mount on the axle has been flipped around. It needs to be shaved a bit on the bottom, but that can easily be accomplished in less than 5 minutes with a file. Check the first and second pics again, too. ;-)
A more detailed look at the lower plate. So, what's going on with Calob? Both of the longer, hex-shaped lower linkage arms are now on the rear and both of the shorter, round upper arms are on the front. Normally this would shorten the wheelbase. Not optimal, imho. I wanted nothing less for Calob, preferably more. Current wheelbase is 12". When you relocate the lower tray the way I have the spacing of the holes in the tray approximately make up the difference of the now-shorter lower front arms. Pretty neat, huh?!?!?!? :mrgreen:
This was just me goofing off with the camera's macro setting. You can see the relocated electronics through the rear. If any of you are going to do this make sure you take a minute to pay attention to positioning of the electronics. I had to reposition the ESC twice because I wasn't respecting the articulation of the rear - the motor wires would have been damaged had I not notice my error. I still need to clean up with wiring a bit, but one thing at a time.
Last detail shot of the front end with the relocated linkage arms and flipped front upper arm mount. Below that is Calob in full compression. The body is completely stock, not modified in any way, as are the mounts and their locations on the frame plates.
There you go. There is Calob. I hope you enjoy my rendition of a Tracer-inspired set up of Redcat's Rockslide RS10XT. I had a goal with this initial build - remove the front suspension and relocate the weight of the battery and electronics with an absolute minimum of cost and work/effort/BS. I'd like to this I have achieved this easily.
Three more thanks are in order ...
Whoever came up with the Tracer frame in the first place ...
MountainStorm - he's already shown us with his Tinker Toy what happens when you run both longer linkage arms on the rear. That, coupled with pelanas build, were what gave me inspiration for Calob ...
cabron - he gets credit on Calob's name. His comment in my servo thread about the quiality of tools and such got me thinking - man i'm cheap, because those tools are cheap Chinese tools (although I guess it goes part and parcel with the truck
). Calob is an acronym - Cheap And Lazy Old Bastard.
"thumbsup" :lmao: 8) ;-)
