Hi
Getting into RC crawling. Previous RC days were a long time ago with a Tamiya Manta Ray, which I’ve been repairing and updating a bit as well.
I’ve got an SCX10 UI UMG10 all set up and running great thanks to a lot of helpful info on this forum. My problem is LEDs. I’ve got 8 LEDs running fine using an RC4WD super bright scale light system. I wanted to put yellow LEDs in the bumper instead of white so bought a 5mm killerbody set of yellows as they were what I could find in stock. Plugged into the controller and they don’t light up (I’ve got the controller plugged into the rx). Made sure the sockets work with the existing LEDs and they’re fine.
Running a Hobbywing Crawler 1080 ESC and 3s lipo.
Killerbody LEDs are wired slightly different and only have 2 wires coming out of the connector then the 2 LEDs are wired between each other. The RC4WD LEDs have 4 wires out the connector (+ and - separately to each LED). I’ve tried to find answers and I’m guessing it’s down to parallel vs series wiring but not sure? I don’t solder so do I just need to try and find some RC4WD yellow LEDs so they’re wired the same and work with my controller? If the answer is yes I’d still like to understand why they don’t work as I’m keen to learn as much as I can. I’ve enjoyed learning about different set ups and the tech during my build.
