here you go..right from the axial shock parts tree.I can't tell from the pic, what are you using in the top of the shock? Stock rubber bushing? And how wide is the chassis?
Damn man do you ever sleep?:shock:
Looks good. "thumbsup"
I just pulled the cab off of my 4.2 and I think I can say I like it. The berg took first this weekend at the PARC comp.:mrgreen:
Can't wait to get mine. "thumbsup"
2 Questions: Are you running a battery mount on the front axle? Why is the front left tire super shiny? :mrgreen:
nice work jeremy
Cant wait to get mine but i guess I have too! From what you mentioned I will enjoy tuning it to my liking also.
I envy you for having all the arsenal at your disposal to develope and enlist manufactures to produce such a nice chassis.
I notice you running shaved boss claw side walls on the rear of your rig, I am yet to run this tire mod, do you think this is benificial on side slops with a consistant contact patch and to also aid forward bite?
most are 70 mm i believe.What length are the springs you run, I ordered a set of those springs you told me about they are 64mm.
Yeah most springs are 70mm but those come in 76 and 64mm, I figured I'd go 6mm shorter rather than longer, we will see.most are 70 mm i believe.
with those you will probably load preload down the difference.
i know there are a few that will know what these are for...
Sweet, what was the bigger plate for?
Do those come with the chassis? :mrgreen:
this will help.
actually the best thing would be for vp to make an extended link mout
What's the thickness of those, I can laser cut some out of aluminum.
Like Krawl said not going to step on anybody's toes with these, if I need some I will make them but do not want to start anything. I am sure if VP themselves do not do something with these someone around here will.Send me a couple when you do8)
