I've read through all the stickied threads a couple times along with a few other related threads... but I am having information overload issues!
I have posted a similar thread in the SCX10 forum as well, looking for additional input.
I've been in and out of the RC hobby for over 25 years, but I have never made the switch over to Li-Po, and I think I would like to finally give them a try.
My budget is flexible. I dont think I need the highest-end stuff, but I dont want to buy crap either...
This will be going into a new SCX10 Wrangler Rubicon RTR with stock 27T motor and AE-2 ESC (for now)... unless I can be convinced I should upgrade these stock components right away, or until they blow (whichever comes first?) :ror:
From what I understand, the AE-2 is rated to handle a 2S Li-Po, although I have stumbled across a quite a few threads claiming sucessful use of a 3S with this ESC. I dont think I need any more than the 2S for my intended use and skill level. I am interested in good power, but even more interested in extended battery life (run time between charges).
With that in mind, I still have some confusion regarding selecting the proper mah and "C" rating. Before all the reading, I would have assumed the higher mah and C rating the better, but after some research it would appear that is a great misconception (regarding scaler/crawler use specifically) What spec's do I need to look for to best suit my intended purpose?
Can you suggest a specific battery size/brand/part # and/or a decent charger for me to consider? Best "value vs. quality" if you will... to help me get started in the right direction.
Thanks in advance, your advice is greatly appreciated!
